maf removal
maf removal
do you just unplug it by yanking the wiring harness off or do you have to unscrew the little thing it is attached to from the maf
-jason
if you are trying to remove the whole maf from the car, loosen the hose clampon the intake tubing and slide that off, unplug(dont yank, just press the button) the wiring harness, then take the top of the air filter box off. There are 4 screws or bolts (cant remember which) holding the maf to the air filter box. REmove those and you're done.
on the wire side of the connector, it should have a button near the middle of it, jsut push it and itll slide off
if you need a pic lemmeknow
