How much would you pay for a plug-and-play FCD?
I made this for myself, but having just incurred the debt associating with buying boostjunkie's old car, I really need some money.
How much would this plug and play fuel cut defender be worth? It connects in series with the lowest of the four ECU harness connectors (easy to install after you remove the lower trim panel, which is just a few Philips-head screws) and uses the "vrg3 FCD Phase II" design.
oh sweet! Man, I don't know how much it is worth. If I hadn't paid a bunch of bills I'd definately try it out, unfortunately I don't have any mods that would make use of htat yet, though. So even if I put it on all I could do is see if I could take it over 6500.
-Ryan
-Ryan
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
Well, it only prevents overboost fuel cut, not overrev fuel cut...
I don't know how much I want for it. I don't really want to get rid of it; I just want funds. :)
To give you some idea of what it might be worth, I had to cannibalize an ECU for the connector.
hmm, well the overboost thing will be a desired soon, but i'm not sure how soon.
I'll look around and see what the going cost for ecu's is. I don't even know what that is.
2014 Volvo S60 T5
2014 Volvo S60 T5
mTk - I've made a couple of ECU extension harnesses that let you do that, but each one required similar cannibalization of parts.
ciper - The connectors are manufactured by AMP. I looked through their catalogs and actually found the later model connectors in there, but I couldn't find ours. I emailed someone at Tyco Electronics (who owns AMP) with pictures including the little "AMP" stamped on the underside to demonstrate that they were AMP connectors, and they told me it must have been discontinued.
$J-MoNeY-$ - I'm not really planning on making more of these (unless maybe if it turns out lots of people are willing to pay for the parts and work required to build one)... PM'd you though.
Hehe. I transferred more than a car over to vrg3
The last time I was at the Crazy Rays, there were a bunch of 90-94 legacies there. They all use the same harness connectors, correct (minus a couple of leads)?
Heh... I haven't a shred of regret about it though.boostjunkie wrote:Hehe. I transferred more than a car over to vrg3
Yes, they do. In fact, I do believe I got the parts used to make this from Crazy Ray's.They all use the same harness connectors, correct (minus a couple of leads)?
Man, I loved that place. Can't find anymore cheap parts for the new car, unfortunately.
I would've loved this plug and play setup for my own car back in the day, especially since part of my problem had to do with the actual wiring harness itself!! Kill two birds with one stone!
Okay, apparently it's worth more to me than most other board members.
Rather than continue the "what's it worth" game, I'll ask this outright:
Would anyone be willing to pay $80 shipped for it? I figure that's about on par with the cheapest commercial FCDs, but this one is plug-and-play for our cars.
vrg3 I'd get it but I can't get it this week.
-Ryan
-Ryan
2014 Volvo S60 T5
2014 Volvo S60 T5
The other benefit to selling it to me is that I dont have a need for it yet since I'm not intercooled. It may be a little while before I am as well, so if you wanted it back inbetween that time I"d be willing to sell it back to you.
2014 Volvo S60 T5
2014 Volvo S60 T5
Hi vrg3, I have an EJ20G engine with EJ22T ECU and have an AVC-R on board. Sometime when I push hard to the gas on around 3000-4500rpm to before redline, the engine hava like "pop",or "Bop" and the AVC-R reading is jumping very high boost like overboost and the car like a fuel cut for a second. will your unit help to solve this problem?
If it does, then I think I will get one from you.
ALso, how much will you going to send to Toronto, Canada?
Ben
Ben
92 Legacy turbo with EJ20G engine swap \(^0^)/
Ben, it's hard to say whether you're experiencing overboost fuel cut or not.
The AVC-R can read many different parameters, right? Are you saying that you get boost spike in the middle of the RPM band? If it stays high for a few seconds then you might be experiencing the fuel cut.
What boost level do you typically run, and what level does it spike to?
If you do in fact have a boost spike problem, I would recommend fixing the spike rather than just fitting an FCD. However, if you do intend to run high boost and fuel cut is preventing it, then an FCD like this one will solve the problem.
Thanks for your fast reply vrg3, I can't tell this is boost cut or boost spike.Are there any way that I could know its going to boost cut or spike?
How can I fix the boost spike, it this case?
Yep, my boost is like from low rpm(3000rpm-4000rpm) is going slow then it "pop"or Bop" then the boost meter shows the boost from 0.8kg/cm jumps to whatever 1.39kg/cm....
It don't happen all the time just once or twice when I have a big foot on the gas.
Please help
Ben
Please help
Ben
Wait, lemme clear up the terminology I was using:
Boost spike is when the boost level rises above your desired level.
Overboost fuel cut happens when boost rises above the factory-set limit (somewhere around 13 psi) for longer than a second or two.
So, if you are actually trying to run 12 or more psi of boost, you may experience fuel cut even when your boost control is operating correctly. If this is the situation, an FCD will solve the problem. A boost level of 0.8 kg/cm^2 (my math says that's roughly 11.4 psi) ought to be okay without an FCD, though.
But, if you're not trying to run such high boost, but the boost spikes, then you should fix your boost control. Perhaps the AVC-R needs some adjustment or something; I don't know much about that device.
You say it's spiking up to 1.39 kg/cm^2?! That's really high, isn't it? About 19.7 psi? I think you need to solve that problem to save your engine, not just to avoid fuel cut. Maybe you could just switch to a simple MBC for the moment.
