hesitation just after startup -- 91 EJ20
Posted: Mon Apr 12, 2004 2:21 am
				The car starts fine and idles well, but from about 30 seconds after
start unitl about 2 minutes after start, the engine boggs badly whenever
you give it a bit of throttle. RPM drop to almost zero -- you can stall it
if you persist. After a couple of minutes everything is fine. No other
drivabilty problems. Codes are 13 and 31. The latter is throttle position
sensor, which makes sense. Any ideas?
The problem might be temperature sensitive. In warmer weather it seems
to take a little longer to appear. I don't remember it ever happening after
a start on a fully warmed engine.
thanks, Chris
thanks, Chris
