Could someone tell me where to get a crank key online.
Posted: Sat Apr 17, 2004 10:02 am
by boosted5speed
I had the same pulley problem as so many other people, i need to order a new crank key, any suggestions for an online place to order one from?
Any suggestions/weblinks would be appreciated , ty everybody
Posted: Sat Apr 17, 2004 11:34 am
by mTk
if a new one isn't an absolut necessity, then i think i have and extra in my garage, it'd be something like 35 cents postage.
MK
Posted: Tue Apr 20, 2004 12:02 am
by mTk
I found mine, it is slightly rounded on one edge, but still works fine. I'd been using it for a long time.
MK
Posted: Mon Apr 26, 2004 8:46 pm
by boosted5speed
hrm thanks for the offer man, but i dont think the one i used (the original one) will be coming out anytime soon, its in there with LOTS of jbweld and its holding pretty well with the new crank pulley
appreciate it much
Posted: Tue Apr 27, 2004 7:39 pm
by DOA
Find an engineering workshop and ask them to make one for you. It shouldnt cost you more than a pint.
Posted: Sat May 29, 2004 7:09 pm
by houseofmiller
I bought a new woodruff key for my Legacy at Lowes. I checked AutoZone and they had an assortment but none of them were quite right. I knew Lowes had some so I went and looked and I found one that matched about 99%. I figure that is close enough. I don't know if they are automotive grade but the way I understand it is if the key is the right size and everything else is in good shape, there is not that much pressure on the woodruff key- it's a part of the system and all parts have their function.
Posted: Sat May 29, 2004 9:36 pm
by evolutionmovement
You actually don't want one too strong anyway. At least most of the time, they're designed as the weak point so they shear and save more important parts from damage. At least that's the idea.
Posted: Sat May 29, 2004 11:33 pm
by free5ty1e
Enlighten me here... crank key? To what does this refer to? is this the thing where we have to make sure our crank bolts are torqued to 110 ft/lbs or else? (or else what? ...exactly.)
Posted: Sat May 29, 2004 11:53 pm
The crank key locates the pulley on the crankshaft and keeps it spinning with the crank. If the pulley is not tightened enough the crank bolt can work loose and the pulley come off if you're lucky, taking your crankshaft with as the key tears out of the keyway it if you're not.
Posted: Sun May 30, 2004 12:13 am
by free5ty1e
OK I gotcha... thanks. I figured thats what this post was about but was jus a lil confoosed about the terminology.
Posted: Sun May 30, 2004 4:01 pm
by magicmike
If you guys already didn't know there is a company called mcmaster carr. They have any and EVERYTHING you could ever need to micky mouse something mechanical. Also, you dont need to be a dealer to order and they have their full catolog online.
Posted: Sun May 30, 2004 6:08 pm
They also ship very quickly, too. I always get things next or two day - that's their standard shipping.
Posted: Sun May 30, 2004 6:53 pm
by magicmike
They have a warehouse out of New Jersey so for me and you it would be one day
Posted: Mon Jun 14, 2004 10:32 am
by BADWGN
bro i just found that shiz out. i got lucky. real lucky. pulley didnt come off, just went crooked and got stuck on cam covers... i was at standstill when it happened, so i guess u can call me lucky.
im needing new harmonic balancer, pulley, few seals, belts, im doing the timing belt while im there, adjusters, and its all happening for about 600 NZD so im pretty stoked, i was expecting much worse, thats cos i got a good mechanice thank god.
more news to come...
