Intake mod #1 will be underway this weekend.
Posted: Tue Apr 20, 2004 8:00 pm
I just picked up some stuff from Home Depot and Advance Autoparts today:
- a few feet of 2" inner diameter pvc pipe
- 2 90-degree elbows
- 1 2.5" hole saw
- some plastic and pvc epoxy
- flat black plastic paint (for the stock look)
I checked out the stock airbox on Sunday and looking at the airbox and pictures of cold air intakes have figured out the proper routing of the secondary (actually, this should be the primary intake pipe since the stocker hardly has a place to suck air from) piping.
Can't wait till this is done. I hear intakes give appreciable gains in mid and high range power . . . although mine won't be one of those conical filter jobbies, I think the limits to the stock intake system have to do with the crappy inlet design on the airbox.
Plus, I can keep some low-end torque that is usually lost with an aftermarket intake. I suspect this has to do with the lack of a reserve champer (ie: intake box) just like the subarus with their small intake plenum.
Of course, a k&N drop in is the next mod. We'll see how this goes.
- 1 2.5" hole saw
