My first drag...little less than hoped for.
Posted: Thu Apr 29, 2004 8:17 am
So anyways, I'm running wrx tires with re-92s, K&N filter, desnorkified intake with the throttle bypass coolant mod. That's about it really.
I've also been having some issues with idle along with really random clutch engagment problems (the position of engagement tends to slip...my plan is to pretty much replace all those hoses and the master cylinder since I've already changed the slave), and then occasionally the car will act like it isn't getting enough boost or maybe the ecu pulls timing. Either way it is like hitting a wall compared to what it should drive like.
So today at the track (my first time) pretty much all those problems were plaguing me except the clutch issue.
My best time was a 17.603 with a trap speed of 79.554. My reaction speed on that run was pretty slow (.699)
On my other 5 runs my trap speed ranged from .1-.3.
My slowest run was 17.957 with a trap speed of 79.046 and the fastest reaction speed. Not only that, but it was also in the evening after dark and after the weather had cooled down considerably.
It was all pretty sad. A friend of my brothers went with me and his n/a 95 2.2L impreza was consistently in the 17.1 and 17.2 (yes a n/a wiped the walls with me
Hardy...<ehem>...Thawa showed up to give me moral support (thanks for showing Thawa) and he was really surprised as well. I ended up just accepting it and shrugging it off. I think I had the slowest time written on my window. there was one slower and that was some old 70's V8 powered van that could only burn one tire. He was at 17.8 on his window, but the run I saw him run was an 18.1.
So this weekend I'll be looking for vacuum leaks, ordering an exhaust and who knows what else.
Oh, and if anyone wants to dispute my times just know this......
I have my timeslips to prove my times!
