				01 impreza RS seats, better fit than wrx?
				Posted: Fri May 07, 2004 10:03 pm
				by czo79
				Hola...
I'm wondering if maybe a set of 01 impreza rs seats might swap into my 91 turbo and still leave my some headroom.  I'd like to do 02 wrx seats, cause they are nicer, and match my rears, but I'm 6'2" and can't deal with a seat higher than stock....
				Posted: Fri May 07, 2004 10:08 pm
				by LaureltheQueen
				if you set the wrx seat at the bottom, it isnt much higher than the turbo seat set at the middle
				Posted: Fri May 07, 2004 11:39 pm
				by eastbaysubaru
				I'm 6' and have '98 RS seats in my car.  They fit perfectly and don't seem to take away any headroom.  When I get around to it, I'm going to try to fit the rails/sliders from my original seats to these seats.  We'll see how long that takes though
-Brian
				Posted: Sun May 09, 2004 2:59 am
				by LaureltheQueen
				the wrx seats are impossible to do this to.  In case anyone was interested.  The seat back is attached to the rail assembly.  I'm not sure when they made the switch
				Posted: Mon May 17, 2004 9:55 am
				by oursTOdestroy
				i looked but cant find any threads pertaining to the rs seats specifically
trying to find out how well the RS seats bolt in to a 92 legacy turbo, can i use the stock rails or do i need the rs rails? cuz i need some new seats like whoa and i found some virtually brand new (2002?) rs seats.
thanks
				Posted: Mon May 17, 2004 4:13 pm
				by LaureltheQueen
				they need the stock rails for the rs if they're 2002, i think my seats are 03, and it was required.  There is one bolt that will not fit, but according to the parts department manager at the local subaru dealership, it's no problem, as there's already 1 bolts in that corner.
				Posted: Mon May 17, 2004 4:18 pm
				by mTk
				nothign is impossible. try fitting your rails eastbay, it'd be neat to see if you can adapt them.
MK
				Posted: Mon May 17, 2004 4:22 pm
				by LaureltheQueen
				try removing the wrx rails.  That will NOT work.  If you DO use your stock rails, then you will damage the impreza rails.
				Posted: Mon May 17, 2004 4:25 pm
				by LaureltheQueen
				Posted: Mon May 17, 2004 4:46 pm
				by mTk
				... and damaging the wrx rails is expected to get the stock rails to work. Any mount or bracket can always be fabricated.
MK
				Posted: Mon May 17, 2004 6:09 pm
				by eastbaysubaru
				IIRC, ciper said the rails from the RS seats come off fairly easily and the Legacy rails bolt right up with an additional hole being needed on the Legacy side of things.  Like I said, if I get motivated at some point I'll try it.  Regardless, the RS seats definitely bolt right in and work well.
-Brian
				WRX 03 SEATS IN 93 LEGACY
				Posted: Fri Jun 18, 2004 3:11 am
				by BATTLEWAGON
				I picked these up off of ebay, $250 shipped.
They came with the orig rails/sliders and they were a perfect bolt in.
I am 5'10 and I have pently of head room, no sunroof though.
Absolutly the best money I have spent on the car to date!
I love this car! I had a VR-4 modded to 430hp befor this, and I have to say this subaru is every bit as fun to drive. my leg is N/A 5sp and when i  keep the revs around 4k it handles better around the twisties, lighter and better geometry than the DSM.
				Posted: Fri Jun 18, 2004 4:36 am
				by BAC5.2
				I'm 6'1, but with the seat all the way up, my head is less than 1" from the roof.
I want to get a set of Sparco Milano's to replace my stock seats.  But I don't have $1600, and I don't know if the Sparco harness bar fits in the Legacy.  Then there is that issue of rolling over.
				Posted: Fri Jun 18, 2004 4:53 am
				by Yukonart
				Phil. . . I'm sure a Sparco or Speedware harness bar could be fit to a Legacy with very little difficulty.  If the width between the B-pillars is the same, I think you're set.  Far as the rollover goes. . . just don't wear 4-point harness unless you're tracking the car.  Even then, if I were to track my car in such a way that rollover was even a remote possibility, I think I'd be looking into a bolt-in rollbar for the backseat area, instead.  In that case, you'd probably just have to have one custom-welded in.
				Posted: Fri Jun 18, 2004 6:50 am
				by LaureltheQueen
				I've got a set of stock rails if someone wants them, $10+ shipping, I'm keeping the seats from my 91(velour's more comfortable than the turbo fabric) and making chairs out of them.
