Parking brake adjusted to limit. It's not enough...
Posted: Tue May 25, 2004 7:44 am
by ultrasonic
I've adjusted my parking brake stroke, and it does not quite reach the spec in the owners manual. It is supposed to tighten in 7-8 clicks. I go 9+ clicks and if the car is on an incline, the brake can just barely hold it. The adjuster is at it's limit, no further slack can be taken up.
Do I have to replace the parking brake shoes?
Will replacing the rear rotors help?
Posted: Tue May 25, 2004 7:57 am
by mTk
Replacing the rotors should not make a difference, unless you have driven w/ your parking brake on. There are ways other than replacing the brake shoes to get it tighter, but not as safe :D
MK
Posted: Tue May 25, 2004 2:55 pm
by Brat4by4
i think you just need a new cable. the old one stretched over time like cables tend to do.
Posted: Tue May 25, 2004 3:23 pm
by NuwanD
seconds on the cable solution
Posted: Tue May 25, 2004 3:28 pm
by entirelyturbo
Same problem here. Any tips on replacing it?
Posted: Tue May 25, 2004 3:34 pm
by mTk
Haha, true i forgot about cable stretching, and in all reality, the brakes don't wear down either if you don't drive on them.
MK
Posted: Tue May 25, 2004 6:01 pm
by evolutionmovement
You could try adjusting it at the brake handle, but good luck - I couldn't get the nuts to move for anything.
Posted: Tue May 25, 2004 6:12 pm
by ultrasonic
evolutionmovement wrote:You could try adjusting it at the brake handle, but good luck - I couldn't get the nuts to move for anything.
That's what I did already. When I bought the car I doubt the handbrake was doing anything at all. I adjusted it using the locked nuts under the arm rest. You have to use two wrenches because it is two nuts tightened against each other to lock the adjustment.
So... brake cable, eh? Do the seats and carpet have to come up?
Posted: Tue May 25, 2004 8:42 pm
by mTk
No, just the center console, everything else is underneath the car.
MK
Posted: Wed May 26, 2004 10:52 pm
Did you adjust them at the back, then? There are little star wheel cylinders under oblong rubber covers on the hub backing plates. You stick a screw driver in to either loosen or tighten the shoes. I forget which way to turn, but it might give you just enough to get the brakes to hold.
