WRX clutch?
Posted: Fri Jun 04, 2004 6:48 am
by Kelly
Will they fit?
I know the WRX clutch is a 228mm, and the Legacy is 225mm.
Is 3mm that big of a difference?
And what exactly is that number? Is it outer diameter? Or inner?
Bueller?
Posted: Fri Jun 04, 2004 6:54 am
by mTk
For a legacy turbo:
Yes,
it is visible, and for the money, might as well get the Bigger
outer, overall diam of clutch disk
MK
Posted: Fri Jun 04, 2004 8:22 am
by BAC5.2
I hope so, I am having one installed right now
Posted: Fri Jun 04, 2004 1:03 pm
by MCO-Ryan
I have one, only difference I noticed was the friction point was much closer to the floor.
Posted: Sat Jun 05, 2004 9:17 am
by Kelly
Cool, Thanks for the replys.
Kelly
Posted: Sat Jun 05, 2004 9:52 am
by Crusher
If I would change to a WRX one. What else has to be changed or does it fit right on?
Posted: Sat Jun 05, 2004 5:44 pm
by mTk
If you buy a WRX clutch kit, it will have everything you need. Clutch disc, pressure plate, throwout bearing, pilot bearing, throwout bearing retainer clip.
MK
Posted: Sat Jun 05, 2004 7:48 pm
by Crusher
Aha, thanks.
Posted: Thu Jul 01, 2004 11:15 pm
by Chi_San
Wouldn't the WRX clutch system fit on a newer Legacy? My old legacy had a cable clutch, but the new 2000 has a hydrolic clutch, smilar to the WRX.
Posted: Fri Jul 02, 2004 12:59 am
by tris91ricer
Will the WRX clutches fit on a 1991 n/a legacy? I'd kinda like to have one, considering i'm up for my yearly clutch replacement...
Posted: Fri Jul 02, 2004 3:56 am
by THAWA
no to both.
Posted: Fri Jul 02, 2004 7:05 am
by BAC5.2
91legacy_sleeper: You go through a clutch once a year? That's not right... unless you drive 100k a year....
Posted: Fri Jul 02, 2004 8:40 am
by THAWA
It is right if you're not conserving the clutch.
