Do i have to screw the pistons in on my 91 4 wheel disc brak
Posted: Wed Jul 07, 2004 9:09 pm
by jlegge007
On my 88 i had to screw the piston in. I dont know about the 91 though. 4 wheel disc brakes.
Thanks, Joe in pa
Posted: Wed Jul 07, 2004 10:42 pm
You mean do you have to turn them to get them to retract so you can install new pads?
You don't. Just push them in. I can usually do it just by loosening the bleeder valve and pushing hard with my thumbs.
Posted: Wed Jul 07, 2004 11:43 pm
by mark10t
Having had an '81, '85 and '87 prior to my Legacy Sport Sedan, boy, does that bring back memories! (If you didn't know about 'screwing the pistons back' on the older Subaru's, it was a lot of 'fun'.)
The Legacy's just push back in. I've usually used a 'C'-clamp to do it.
-Mark
Thanks!
Posted: Mon Jul 26, 2004 7:18 pm
by jlegge007
I will put the c-clamp on them.
Posted: Tue Jul 27, 2004 12:00 am
Cool. When you do, put the old brake pad between the clamp and the piston so that the clamp's hard steel surface doesn't hurt the piston.
Posted: Mon Aug 23, 2004 7:13 pm
by greg donovan
mark10t wrote:Having had an '81, '85 and '87 prior to my Legacy Sport Sedan, boy, does that bring back memories! (If you didn't know about 'screwing the pistons back' on the older Subaru's, it was a lot of 'fun'.)
-Mark
i did my pads on my 85 and didnt turn the page on my manual when studying up on what needed to be done. needless to say i got everything apart and then turned the page. had no way to turn the damn piston in. fortunately had access to another car. it took 4 auto parts stores to get a somewhat special tool. and it was a universal one that sort of worked. man did that suck. what a stupid design. and then to have to deal w/the ebrake on the front too. what a pain. total start to finish time for left side:
4 hrs. (this includes searching around town)
total for right side:
20 minutes.
last fall i did all four corners on my 90 legacy. took half hour/45 min. tops, including clean-up. man i love my legacy.
Posted: Mon Aug 23, 2004 10:12 pm
by BAC5.2
Took almost 2 hours to do my drivers side brake pads on my SS. Wicked bitch. Ran into so many issues from stripped heads, to stuck brackets. Ugh, way to much effort required.
Posted: Tue Aug 24, 2004 1:28 am
by LaureltheQueen
i did my front pads and rotors myself, and will eventually replace my rear pads as well, when i have a free afternoon
go me
