What's the best way to pull off the VIN from the dash?
Posted: Thu Jul 08, 2004 4:55 am
by georryan
Its riveted in there isn't it? I just changed to the black interior and I want to make sure that I keep the VIN from the old dash (so every time I smog it I won't run into problems potentially), but what is the best way to pull that off?
Posted: Thu Jul 08, 2004 6:17 am
by THAWA
heh, I had thought about that, and wanted to ask you about it but totally forgot.
Posted: Thu Jul 08, 2004 7:01 am
by azn2nr
dremel it
Posted: Thu Jul 08, 2004 6:04 pm
Take a drill.....drill out the pop rivet core.....then swap plate......re-pop rivet it back in there.
Posted: Thu Jul 08, 2004 6:14 pm
by georryan
Cool, thanks!
Posted: Thu Jul 08, 2004 7:27 pm
by mTk
what josh said, drill out the rivet and rivet the new vin in.
So far i've just left my old vin on the old dash piece, which i'm not sure where that is..
MK
Posted: Thu Jul 08, 2004 9:39 pm
by georryan
Well....the dash is already in the car.... which will make it hard to stick on there right. I guess I could just super glue it in place or something.
Posted: Thu Jul 08, 2004 10:53 pm
You could use pop rivets to install the new plate.
Posted: Thu Jul 08, 2004 11:18 pm
by evolutionmovement
Thin double-sided tape. Its what the criminals in my novel do all the time also changing to new VIN-matching plates courtesy of their people in the DMV.
