Knock sensor wire
Posted: Thu Jul 15, 2004 10:35 pm
I FINALLY found out why I was throwing code 22, the wire leading to the white connectors from the main batch of wires to the knock sensor, is SMASHED in between where the tranny mounts to the engine
. I blame AAMCO. Sooo I think I could cut the wire and bypass it, or see if AAMCO could take it out when I take it in for their 500 mile check. It is most likley that the wire is touching the block and inhibiting it and causing the computer to think that there is no Knock Sensor. Not to mention the wire looks like it was repaird long ago, cracking electrical tape.
One problem down. next up, figure out why my IC setup feels like its leaking untill it gets warm
