cheapest way to lower 94Ti wagon
Posted: Fri Jul 23, 2004 7:52 am
by The Scooby
ok i got a set of front and rear struts, my Ti wagon has air suspension on it and i want to lower it.
so i picked up the struts and stock springs, i dont want to cut.heat the springs because i dont watn that dumb bouncy ride,
any ideas??
Thanks,
Shean
Posted: Sat Jul 24, 2004 7:51 am
by BAC5.2
Get new springs. $172 for some Tein S-Techs.
Otherwise cut the springs.
Posted: Sun Jul 25, 2004 3:53 am
by THAWA
Posted: Sun Jul 25, 2004 7:15 pm
by scottzg
pop your tires.
You probably wanna steer away from the stechs because they are a progressive spring and the stock shocks are linear. Good choice to stay away from cutting, there is some tapering of these springs so the diameter wont be the same if you cut, also, the coils are not all the same width and you will load the new fresh cut tip.
Check out the stickied suspension info compendium.
2.5rs springs off nasioc would be a cheap option.
You will need some rubber things and some nuts and some top mounts too- this might be more expensive than you think. Be aware that the rear springs are different in 90-91 and 92-94 models.
Posted: Mon Jul 26, 2004 8:18 am
by The Scooby
ya i know the differences, i worked at a subaru wrecking yard here in seattle for a while and know quite a bit about bodystyles and such, just nothing about the interchangability of springs.
Shean
Posted: Mon Jul 26, 2004 11:18 pm
by The Scooby
ok i just got a set of 03 WRX wagon springs and was wondering if they will work on the legacy struts?
i paid $40 for them is this a good deal?
Thanks,
Shean
Posted: Mon Jul 26, 2004 11:49 pm
by LaureltheQueen
You work at Aarons? What's a Ti?
Posted: Tue Jul 27, 2004 12:01 am
by The Scooby
i used to work at aarons, my last day was last thursday so i would have a week to pack for college.
a Ti was the outdoor wagon, the airsuspension gives you a 4inch lift for offroading, full skid plates, different interior, side decals etc etc.
Posted: Tue Jul 27, 2004 12:54 am
by LaureltheQueen
cool! never heard of one of those
Posted: Tue Jul 27, 2004 5:37 am
by eastbaysubaru
It really has skid plates? If so, could you take some pictures of the undercarriage?
-Brian
Posted: Tue Jul 27, 2004 6:28 am
by LaureltheQueen
if you're dropping it while you're still in town, I'd love to lend a hand or if it's not too much hassle, at least get a look at the air suspension setup
Posted: Wed Jul 28, 2004 6:57 am
by The Scooby
ya i wont be doing the suspension swap before i move, it will be sometime while im attending college, just dont have the time now.
but again, does anyone know if the rex springs will work??
Thanks,
Shean
Posted: Wed Jul 28, 2004 7:39 am
by THAWA
someone is going to tell you to remove the picture in your sig
Posted: Sat Jul 31, 2004 5:25 pm
by LaureltheQueen
wrx springs will fit... bu the spring rates are different, because the wrx is a lighter car, and definitely doesnt way as much in back. Dunno how it'd look. You could TRY it.
Posted: Sun Aug 01, 2004 3:16 am
by THAWA
LaureltheQueen wrote:doesnt way as much in back.
laurel, I'm shocked!
