Sway bar compatibility (turbo related)
Posted: Mon Aug 04, 2003 5:48 am
by ciper
I see many times that when WRX (ej20) engine swaps are performed the recomendation is to use a Legacy turbo cross member if the WRX unit is not available.
As you probably know the NA legacy bars will not fit the turbo cross member.
I KNOW there are some later Impreza/Legacy with Legacy turbo cross members driving around. Sway bars arent normally included with a cross members. Could this mean they are using WRX sway bars on the Legacy turbo cross member?
Im going to need to replace my 22mm Whiteline front sway bar after an engine swap Im looking for alternatives. It sure would be nice to be able to grab any WRX aftermarket sway bar to match the 22mm rear adjustable bar I have now.
Im going to ask on NASIOC as well, if any of you are in the Bay Area and know of a stock WRX bar that I could borrow that would be really cool.
Otherwise I guess Ill order the BSF18X and wait a freaking year for it to arrive :roll:
