Need some help from you AT driving turbo legacies
Posted: Tue Aug 03, 2004 11:26 pm
As you may or may not know I'm doing a 5mt & awd swap. I'm using the turbo legacy tranny, which requires me to put the clutch MC on the firewall. There is no hole on my car.
I have heard/seen that on the turbo legacies. They all had the hole, it was just covered up with a rubber grommet.
What I was wondering is if anyone could take some measurements/orientation of the holes for the clutch MC, and possibly relate those holes back to two other reference points, so I could get pretty close or exactly where I needed to cut out the hole.
I was thinking and the easiest way to do this would be to just stick a piece of paper on the firewall where the holes are, trace them, and then either do the same for the two reference points, or cut a slit in the paper so it lays roughly flat on the firewall.
Assuming I can get a good templete, I will post it along with my full writeup when I get done.
TIA.
TIA.
