Hubs & backing plates
Posted: Mon Aug 16, 2004 2:56 am
Curious if the backing plates on the rear hubs can be taken off easily?
I'd sort of prefer to use the ones on my car rather then the donor. Plus I accidently banged on one of the studs, and the tip of the threads is a little marred. I'd like to knock out of the studs on mine to use it.
Is swapping the backing plates and or changing studs something I'll need a press for, or do I just have to take apart the parking brake stuff?
