Decent rally shocks for 90 legacy sedan?
SuperRallyRoo
Post by SuperRallyRoo »
My car needs some new shocks bad I compete in rally crosses alot and it bottoms out cause its basically all spring now... I don't want to just replace them with stock ones I want because I plan to race this thing sometime in the future. I know nothing squat about shocks I know I like bilsteins because I have them on one of my volvos and that thing handles amazingly. Where would I go to look for shocks in the 500 or less $ range? Or is that to cheap? I will install them myself.
Legacyless
98 Jetta TDI
greg donovan
Post by greg donovan »
where are you?
for rally cross the kyb gr-2 will work just fine and they have a lifetime warranty. i have them on mine. and my brother used them on his impreza. they are around 250 from http://www.discounttiredirect.com/direct/home.jsp i will dig out my bill from them and give you the name of the guy i talked to if you want. he was very helpfull. i am very happy with their performance.
the agx would be good to. they are 4 way adjustable in front and 8 way in the rear. however the set on my wagon has not been changed in 5 years. they are around 400.
i would reccomend the gr-2 and a custom wound set of oem style springs in the same (maybe a 1/2-1 inch higher) height but a slightly higher rate. talk to doug davenport at http://davenportracingusa.com/ about getting some custom springs. this combo would be right around your 500 mark.
mike wray uses the agx w/ground control coilovers on his turbo rally car and it seems to be working really well for rallyx and good enough for our "smooth" rallies here in minnesota.
plus stock pieces are around 110 a piece from the dealer so stay away from them.
mike is going to be running at OFPR this weekend so i will ask them how they are working in a harsher environment.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
kastrix
Post by kastrix »
Where have you found the agx's for 400 bucks?
I havnt looked that many places and the cheapest i've seen them was around 600
@The Beast@
1992 Legacy L 5MT
Exhaust, tint, fogs, anti-snorkus, plugs, wires, rims, tires, stereo and shifter knob :-)
A good car is like a good woman...
She will turn on when you want her to and she will always give you the ride of your life.
greg donovan
kastrix wrote:Where have you found the agx's for 400 bucks?
http://home.att.net/~teaguesauto/suspension.htm#Struts .
this is a very good retailer. 449. they say for imp. but IIRC they work on our cars too. i have them on my wagon.
and i believe we discovered that the 92-94 gr-2 is the same as the 90-91 gr-2 but the "newer" one is 100 cheaper. and the imp ones for 249 should work too.
if im wrong on parts mix and match someone please correct me.
ACP put GD chassis stuff on his car i believe and its a 90.
you can also look here:
http://www.spdusa.com/prod01.htm
mike shields was who i bought my agx's from for 440 w/shipping 5 years ago. and his prices seem to not have changed much. he trashes the legacy abit on his site but he is a little more helpfull on the phone.
96 Impreza L sedan
00 Impreza RS sedan
greg donovan
read this thread started by ACP about putting the GD WRX stuff on his 90 AWD sedan:
http://bbs.legacycentral.org/viewtopic.php?t=15919
its got some good stuff in it. and he knows rally.
this is him in the evo in the last pick in this thread:
http://bbs.legacycentral.org/viewtopic.php?t=17843
96 Impreza L sedan
00 Impreza RS sedan
SuperRallyRoo
Wow I sounded retarded when I made this post haha. Anyway ya those GR2's sound good but i sure wish they could be adjusted like the AGX's. I'll come back to this topic when i get my paycheck next week :wink: And to the person who is going to ask the guy with the rally legacy about how his stuff is holding up... Yes please ask him, but I will also be going to WCSS6 on friday-sunday and will probably be able to ask a bunch of people there. :o
Legacyless
98 Jetta TDI
greg donovan
on my wagon the agx has not changed settings since i got them. the changes went from good handling to annoying real fast. the gr-2 is a nice compromise and i dont think the adjustability is worth the nearly double in price.
96 Impreza L sedan
00 Impreza RS sedan
greg donovan
just talked to mike about his AGX/Ground Control setup. says its holodng up good so far but that is only w/two events. but there was some rough stuff at OFPR this past weekend.
unfortunately he rolled on sat. just cosmetic damage and they are both ok.
96 Impreza L sedan
00 Impreza RS sedan
