Power Pulsing
Posted: Mon Aug 11, 2003 6:10 am
Hi,
I've got a factory 92 Gt legacy turbo. I recently found that the outlet for the tubro boost controller solenoid valve had been deliberately blocked up! I cleared it & now the car boost much harder (10psi instead of 5) BUT the power pulses baldly, especailly if you put your foot down! What may cause the power to fluctuate quite badly (while maintaining fairly high boost)? It tends to pulse less when you only put your foot halfway down. maybe the knock sensor? I've put in higher octane fuel (98 instead of 96) & it made no difference.
Thanks for your help.
Luke
Luke
