4eat to 5MT
dzx
4eat to 5MT
Post by dzx »
i thought i read somewhere on the legacycentral website about dave or someone cutting a certain wire after making their swap and it keeping the engine from revving up before going back down when the clutch is pushed in. My car stays revved for a long time after i start it cold and everytime i push in the clutch, the revs go up before they go down. Anybody care to make a quick explanation please
THAWA
Post by THAWA »
did you do a swap aswell?
DLC
Post by DLC »
See the top of this page:
http://legacycentral.org/library/transm ... ronics.htm
B48.20 is the wire i cut.
Legacy Central
dzx
Post by dzx »
yeh, i did the swap too. a 4.11 98' rs tranny using a cable with a fidanza flywheel, and exedy clutch
Tha cable can handle the stronger clutch?
THAWA
Post by THAWA »
wow someone else is using a 98 rs tranny :)
I thought the RS trannies were hydraulic. Did you convert it to cable?
THAWA
Post by THAWA »
The only difference is the clutch fork and where it pivots. If you use a cable fork, and move the pivot to the lower spot (I believe, there's only two anyway so either one or the other) you'll be able to use it. And before anyone asks, even though it's hydrolic, it's still a push style clutch system.
dzx
Post by dzx »
The cable doesnt have any problems, i didnt like the feel of the hydrolic clutch lol and thawa is right its a push style
