No more MBC?
Posted: Mon Sep 06, 2004 6:31 am
OK, I'm curious...
I've been thinking about the Turbosmart e-boost for a while. I like it a LOT because it holds the wastegate shut until full boost is acheived.
I was thinking about how this could be done without spending $400 for the E-boost.
What about a check-valve in place of the MBC?
Say you want 15psi of boost. The check valve would be shut until you hit 15psi, then it would open and the wastegate would open up. Keeping the wastegate shut while spooling would help spool times immensely (all exhaust would be going through the turbine).
Would it work? Why wouldn't it be a good idea?
