Car now has no spark!!!
Posted: Sun Sep 12, 2004 1:14 am
by jake15
my car seems destined to thwart me...... car started fine in the morning, so i was like yeah!! then i put the exhaust and the bumper on (bumpers just sitting in place) and took it for a spin around the parking lot. worked great. took it out for a couple more and each and each time the car would die more, but i didnt notice at the time, then i finally parked it and when to go get lunch, came back and it would start but idled really low and then when the gas was pressed down it would slowly rev up to about 750 and then die (it also clicked at the throttle body). let it sit over the weekend and came back to see if it would run (still didnt run) so we checked the basic stuff (see if it was getting any gas, spark, and stuff) it turns out there is no spark. i'm stumped so far and again i am calling out for help. thanks,
jake
Posted: Sun Sep 12, 2004 3:49 am
by petridish38
Just for the hell of it, check your crankshaft pulley and bolt. See if the bolt is tightened enough. Even though you should still be able to get a spark with a loose bolt, your symptoms sound like they could be caused the pulley.... Might as well check it to clear that off the list of possibilities....
Andrew
Posted: Thu Sep 16, 2004 1:02 am
by jake15
Checked the crankshaft pulley/bolt, but thats not the culprit. if it is any help i did repair the cam/crank/knock sensor wires due to them being all brittle from being right next to the turbo..... i really need help, this car has to be up and running by the middle of october. thanks,
jake
Posted: Thu Sep 16, 2004 6:58 am
Is the battery in good shape?
Can you hook a scope or at least an analog voltmeter to the crank and cam position sensor signal lines to see if they're both outputting a signal?
Have you checked to see if the ECU stored any trouble codes?
Do you have access to a spare ignitor and/or ignition coil pack that you could swap in?
Does the Check Engine light come on when you turn the ignition on?
Are the injectors pulsing?
Posted: Fri Sep 17, 2004 2:40 am
by jake15
i just took the intercooler off (major PITA) and guess what i found... the camshaft sensor plug had wiggled loose
i'm not sure if it was the sensor or not so i will run some "tests", but hopefully it was just from being unplugged. thanks for your suggestions,especially vrg3 (my car wouldnt be running if it wasnt for you). thanks again
jake
Posted: Fri Sep 17, 2004 2:50 am
You're welcome.
Woah, a disconnected cam angle sensor... that's almost certain to cause some trouble. Plug it back in and let us know.
Posted: Fri Oct 08, 2004 1:37 am
by jake15
*update*
i took the i/c off and plugged in the cam sensor, put it back together and it still didnt start, check today and the car now has spark and gas, but it still doesnt run......... i'm still very confused
Posted: Fri Oct 08, 2004 4:19 am
Hm. Does it even start to catch when cranking?
The battery's well charged, right?
Posted: Fri Oct 08, 2004 4:23 am
by jake15
battery is kind of dead, but when starting it had a jumper box on it. it turns over and sometimes it catches and starts but dies immediatley. no codes are thrown and it doesn't run long enough to check everything on the scanner.
Posted: Fri Oct 08, 2004 4:28 am
Is it possible the cam belt jumped a few teeth or is otherwise damaged?
Posted: Fri Oct 08, 2004 4:09 pm
by jake15
it is possible, but i just replaced it...
Posted: Sat Oct 09, 2004 1:40 am
Hm. It's worth taking a look at...
The ECU didn't store any trouble codes?
Posted: Sat Oct 09, 2004 1:49 am
by jake15
nope, the ecu is free of all codes, history and all.
i will look at the timing belt, it cant hurt
Posted: Sat Oct 16, 2004 11:51 pm
by jake15
the car now works!!!!! we figured out it was a combination of one plug that was barely plugged in, my re-wiring of the knock sensor (rewired them again), and the spark plugs being completely black )(from running rich). fixed it all and so far so good. i need to cut up my spare hood for the hoodscoop and get my hands on a boost controller
12psi here i come
thanks for all the help... again
Posted: Sat Oct 16, 2004 11:56 pm
Cool, glad you figured it out. So the spark plugs just weren't firing?
Posted: Sun Oct 17, 2004 3:37 am
by jake15
yeah i guess so... it had weak spark before from the not so good rewiring job i did, so i think the combination of that just caused the spark plugs to not fire. i took it for a drive and it runs and drives good and pulls nicely for the stock boost levels
