Rear Handle and mounting bracket for a wagon
Posted: Tue Oct 05, 2004 12:45 am
by Gotta Jibboo
I recently took apart my wagon's rear hatch to try and figure out why it isn't working. Well, sure enough, the plastic handle broke off of the metal rod which opens the door, and, sure enough, when I took the handle off, the little mounting bracket for it was soooooo rusted that I was almost able to bend it totally in half (double it over itself).
Sooo, as you can probably tell, I'm in need of a new bracket AND a new handle if I want to open my trunk again...
Anyone happen to know the part numbers for these two parts, or know where I could find the part numbers?
Thanks a lot guys
Posted: Thu Oct 07, 2004 11:28 pm
by LaureltheQueen
call your nearest subaru parts department. :)
Posted: Fri Oct 08, 2004 5:32 am
by evolutionmovement
I replaced my handle for like $12 at the dealer. They all go eventually unless maybe you diligintly spray it with some kind of protectant.
Posted: Sat Oct 09, 2004 1:16 am
by HomeSlice
i may have a working spare
Posted: Sat Oct 09, 2004 6:41 pm
by Gotta Jibboo
homeslice, that would be fantastic, I'll give you 20 bucks plus shipping for 'em
Posted: Sat Oct 09, 2004 9:44 pm
by BAC5.2
Gotta Jibboo wrote:homeslice, that would be fantastic, I'll give you 20 bucks plus shipping for 'em
You did see Steve's post above that it cost him $12 NEW at the dealership... Right?
Posted: Sun Oct 10, 2004 6:19 am
Usually its the women who don't listen to me. :)
Posted: Sun Oct 10, 2004 3:00 pm
by Gotta Jibboo
yea, I did see Steve's post, but didn't you see my post that I need the handle AND the mounting bracket?
Unless I misunderstood your post Steve and you got both for 12 bucks, in which case I stand corrected. But it seems like you only got the plastic part for 12 bucks, I need the metal part it mounts too as well
-James
Posted: Sun Oct 10, 2004 8:37 pm
The two are built together.
Posted: Mon Oct 11, 2004 1:16 am
by Gotta Jibboo
well in THAT case, 12 bucks it is
Thanks Steve
Posted: Tue Oct 12, 2004 4:07 pm
by 90LegAWD
how the heck do you replace it though? it looks like it's riveted to the liftgate.
Posted: Tue Oct 12, 2004 10:33 pm
I believe it's two nuts on the inside ... hm ... eh forget it. Yeah, pull the panel and they should be pretty easy.
Posted: Wed Oct 13, 2004 12:09 am
by Gotta Jibboo
yea, you pop off the inner plastic panel, remove the two nuts a couple inches under the washer motor, take the metal rod off of the handle, and tada! Wicked easy.
Thanks a lot for your help guys, I'm heading down to my dealer tomorrow.
-James
Posted: Wed Oct 13, 2004 2:50 am
by 90LegAWD
SWEET. i'm ordering one tomorrow!
