turbo front brakes
Posted: Tue Oct 19, 2004 12:12 am
by scottzg
Are they the same size as N/A fronts?
Posted: Tue Oct 19, 2004 2:04 am
nope
the calipers are two piston calipers, and the rotors are larger
Posted: Tue Oct 19, 2004 2:20 am
by scottzg
is it the same caliper bracket?
Posted: Tue Oct 19, 2004 2:22 am
by 90LegAWD
do they fit under 14", or is 15" required?
any pics of the difference?
Posted: Tue Oct 19, 2004 2:26 am
Legacy Turbo brakes won't fit under 14" wheels.
I thought some BC/BF non-turbos got the bigger brakes too... the ones that came with 15" wheels...
Posted: Tue Oct 19, 2004 2:28 am
by legacy92ej22t
scottzg wrote:is it the same caliper bracket?
I don't think so but I'm not 100% sure. IIRC the turbos is slightly bigger.
90LegAWD wrote:do they fit under 14", or is 15" required?
They won't fit under 14" wheels. You need at least 15".
Posted: Tue Oct 19, 2004 2:29 am
by legacy92ej22t
Again Vikash, you sneak in while I'm typing!
Posted: Tue Oct 19, 2004 2:36 am
I'm the reply-sniper!
Posted: Tue Oct 19, 2004 2:39 am
by 90LegAWD
very interesting. so, will the turbo caliper bracket bolt to the NA hub/spindle?
Posted: Tue Oct 19, 2004 2:48 am
Yes, it will. If you get turbo calipers, brackets, and rotors, they'll all bolt right on.
If you have 16" wheels, though, you might consider using WRX front brakes rather than Legacy Turbo ones.
Posted: Tue Oct 19, 2004 2:57 am
by THAWA
vrg3 wrote:I thought some BC/BF non-turbos got the bigger brakes too... the ones that came with 15" wheels...
I didn't know there were any NA's with 15" wheels, The largest I know about are the 14x5.5 that were on the top of the LS in 90 then changed for the 91-94 LS and LSi.
I believe the BF's share the same caliper in the rear as the turbo legs, and interestingly the SVX. Lemme double check taht though.
Posted: Tue Oct 19, 2004 2:59 am
Oh. I'm just thinking of all the times I've looked brake parts up in various catalogs and they have a listing for "w/ 15-inch wheels" that has the same part numbers as "w/ turbo." But maybe those two categories are identical because they're the same cars.
Non-turbo BFs have the same size caliper piston in the rear as turbo cars, but the caliper's different because it has to fit a wider rotor.
Posted: Tue Oct 19, 2004 3:01 am
by THAWA
oh right, I was wrong about it anyway. But to add to the interesting factor (at least to me) The NA sedans have the same rear caliper as FWD SVX's and the NA wagons have the same rear caliper as AWD SVX's. Yes I know this adds nothing to the discussion, but oh well
Posted: Tue Oct 19, 2004 3:15 am
yeah, as it's been mentioned. The brackets are different from the n/a legacy front brakes. They will however bolt to the n/a just fine.
You will need 15" wheels.
Posted: Tue Oct 19, 2004 4:32 am
by entirelyturbo
Am I not correct in stating that 2.5RS brakes are identical to Legacy Turbo brakes?
Posted: Tue Oct 19, 2004 5:31 am
by THAWA
yes you are not correct, I think josh or osmeone said they use the "newer" design caliper. Part numbers are differnt aswell.
Posted: Tue Oct 19, 2004 6:05 am
by scottzg
yup. the 2.5rs can just put a different caliper bracket on to use wrx brakes.
Posted: Tue Oct 19, 2004 3:03 pm
subyluvr2212 wrote:Am I not correct in stating that 2.5RS brakes are identical to Legacy Turbo brakes?
Nope they're different. The bracket design is different, which in turn does change the caliper itself a little.
