Headlight adjustment---how to?
Posted: Mon Oct 25, 2004 5:55 am
by ej22t
Hi People, just installed an aftermarket HID kit to my 92 Legacy turbo and now have to find out the way to adjust the beam of the headlight.
On the owner manuel it just shows how to read the indicator but doesn't say how to adjust it.
I found out there are 2 of 5/16 or 8mm bolt behide the headlight. The other bolt are adjust for the up an down, but how can I adjust the left to right?
What does the inner bolt do?? Also there is a meter with L and R on top of the headlight, how do I adjust it?
Thanks for help!
Ben
Posted: Mon Oct 25, 2004 6:00 am
You should get rid of that HID hackjob. It's ruining your headlights' beam pattern. There's no way to aim your lights to work correctly now.
