3 out of 4 ain't bad, F%&$# it !!!
Posted: Mon Oct 25, 2004 4:05 pm
Picked up a mint set of WRX wheels and set about putting them on yesterday. After a two hour search for lugnuts, first finding them in all sorts of neat colors but not chrome, I installed three of them, and then...
The left front wheel won't come off. Now, I've removed certainly hundreds of wheels, some of them pretty stuck, but this takes the cake. The screwy thing is I have a receipt for a front rotor job that was done on this car in January, and indeed the rotors appear fresh. The lugnuts were also a biotch on this hub, and normal on the others.
Two hours of beatings, swearing, pry bars and all manner of unwise things and nothing.
Its pickling in penetrant right now and I just went out into my plant and got the huge gear puller assembly, which should fit in the little holes in the steel wheel. Tonight it dies !!!
I must say the WRX wheels look better than I though on the wagon, I first wanted GT wheels but have changed my mind, the WRX wheels look larger and more bold. I also noticed that the RE92 rubber is very narrow compared to Bridgestone 205/55 that I have on the BMW, the Bridgestone RE730 ZR's. Big difference in effective treadwidth. I think the RE730 would rub the spring perch in the back, probably; the RE92 are fine.
