chimney removeal?
Posted: Tue Oct 26, 2004 2:37 am
by azn2nr
just as the subject says. how do you remove the chimney. im looking in my haynes and it doesnt tell me. i did some snoping around with a flashlight and cant find or see any bolts other than a few uppipe bolts hiding down there. can anyone give me some directions.
Posted: Tue Oct 26, 2004 2:51 am
by mikec
There's 3 bolts around the backside near the top, and if I remember correctly, one down the passenger side that attaches it to the downpipe heatshield.
If you need a picture tomorrow, I can grab one for you.
Posted: Tue Oct 26, 2004 3:01 am
I remember there being a total of seven small bolts holding it in. It helps to have a ratcheting box wrench. Just feel all over its surface for them.
All the bolts have 10mm heads.
This picture might help:
http://www.graphics.cornell.edu/~v/pics/chimney.png
Posted: Tue Oct 26, 2004 3:03 am
by mikec
Weird. My car only had the top chimney piece. And the car came to me completely stock.
Posted: Tue Oct 26, 2004 3:06 am
The lower part is actually bolted to either the uppipe or downpipe I think.
Are you sure it's not deep down there? If not, someone must have removed your turbo at some point in the past and removed it.
When I pulled my turbo I was really surprised to find a missing bolt on the compressor inlet elbow. I guess someone must have removed my car's turbo before.
Posted: Tue Oct 26, 2004 3:09 am
by azn2nr
that picture you posted helps alot. its just making me dizzy. now i just have to wait till tomorow to attempt to do it.
Posted: Tue Oct 26, 2004 3:11 am
by mikec
Hmm.... There's no way of knowing anymore, as totech has my stock exhaust. :) I do still have the top part installed.
Forgot: This probably doesn't need to be said, but you should probably soak them in penetrating oil for a bit first.
Posted: Wed Oct 27, 2004 4:22 am
by BAC5.2
7 total bolts.
Mine fell off when Matt and I were doing my intercooler install. I think there were 2 bolts holding it on, and they were each only half threaded in.
Posted: Wed Oct 27, 2004 4:27 am
by legacy92ej22t
Hehe, ya, that thing was barely on there.
Mine had a wicked rattle for a while before I removed it and it was only from one missing bolt.
Posted: Wed Oct 27, 2004 4:30 am
by mikec
Mine's rattling now that I can't use the lowest mounting hole. I don't know what I'm going to do about it.
Posted: Wed Oct 27, 2004 4:35 am
by BAC5.2
Take it off.
Posted: Wed Oct 27, 2004 4:37 am
by mikec
I had it off, decided to put it back on... If I can't tweak it just right, it'll definitely be coming back off.
My car's got enough noises already that I don't need another one. Plus it ends up being weight savings I guess :)
Posted: Wed Oct 27, 2004 4:46 am
Figure out a way to shim the space where it rattles... Little chunks of aluminum foil might do it.
If you can keep the chimney, it's a good thing.
Posted: Wed Oct 27, 2004 4:48 am
by mikec
Yeah Vikash, I'd like to keep it on. I'm gonna spend some time tomorrow looking at the clearances. I may have to trim some more, or find a way to preload the chimney so it can't flex.
