Is this clutch any better then OEM?
Posted: Thu Oct 28, 2004 10:14 pm
by legacy92ej22t
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33730
Just wondering if this is a bit better then OEM (wrx) or the same.
Also, is $80 shipped for a OEM WRX clutch and flywheel w/9k easy miles a good deal?
TIA
Posted: Thu Oct 28, 2004 11:53 pm
From my understanding, exedy makes the OEM subaru stuff, so that's going to probably be like stock, or slightly better
Yeah I'd say 80 bucks is pretty damn good deal, assuming everything is in good shape. Is the pressure plate included too?
Posted: Thu Oct 28, 2004 11:59 pm
by astv5l
but would that clutch fit our Legacy SS's?
Posted: Fri Oct 29, 2004 12:02 am
astv5l wrote:but would that clutch fit our Legacy SS's?
It will fit, along with the wrx pressure plate, but you must replace the flywheel w/ a wrx one as well.
I've got a wrx flywheel, clutch, & pp on my legacy.
Note, the wrx clutch, pp, & flywheel will only work on the turbo legacy trannies.
Posted: Fri Oct 29, 2004 12:43 am
by legacy92ej22t
Yep, it comes with everything.
Posted: Fri Oct 29, 2004 12:46 am
by astv5l
Sorry for the dumb questions, but what is the advantage of replacing with WRX flywheel & pressure plate, and is there anything else needed to do the conversion?
Posted: Fri Oct 29, 2004 12:54 am
by legacy92ej22t
It allows us to upgrade to aftermarket clutches for the WRX, which are much more abundent then ones for the SS. It's also slightly larger.
Posted: Fri Oct 29, 2004 2:22 am
by legacy92ej22t
Crap! I lost the action. :cry:
Still looking I guess...
Posted: Fri Oct 29, 2004 2:26 am
by astv5l
is there anything else involved in swapping in a WRX clutch other than clutch, flywheel and pp?
Posted: Fri Oct 29, 2004 3:13 am
nope.....that's it.
Posted: Fri Oct 29, 2004 4:59 am
by BAC5.2
I'm running the Exedy Stage 1 for a WRX with a Exedy Lightweight flywheel for the WRX. Works just fine :)
My Exedy setup has been holding onto my power for quite some time.
Matt - That clutch is OEM, probably no better than OEM. I have seen a few Stage 1 clutches go on e-bay (unused) for pretty cheap, around 200 bucks.
If I worked at Subaru I could get you a good deal on the SPT STi upgrade clutch. It's a 3-puck though. 3-puck = teh suck for street driving and I've heard complaints of life. Someone burned an ACT 3-puck in 10,000 miles.
