phase 1 doch top end worth it?
Posted: Tue Nov 09, 2004 1:32 am
by azn2nr
ive been given the oppertuinity to buy a complete phase 1 doch top end (heads manifold rails and injectors) for 600 dollars. would it be worth the money and the hassle to attempt. and will in need to get engine management first?
Posted: Tue Nov 09, 2004 1:37 am
by Subaru_Nation555
I'm not familar with this so some of these questions might seem trivial. What kind of car do you have? What type of injectors? If they are higher flowing injectors then stock then they are easily worth the $600 because aren't the nismo injectors that fit our cars over $800? My guess is that some kind of engine management would be needed but I'm not really sure.
Posted: Tue Nov 09, 2004 1:54 am
by azn2nr
92 ss. with the new heads and injectors id be modding them for higer flow. bascily everything gut the block will be replaced
Posted: Tue Nov 09, 2004 4:05 am
by 91White-T
600$ seems kinda steep. Maybe for an entire motor, but not for heads and manifold.
Posted: Tue Nov 09, 2004 4:57 am
by azn2nr
really, sounded good to me. they were just rebuilt so their brand new
Posted: Wed Nov 10, 2004 2:31 am
by Matt Monson
That is a good price for all that stuff. You could run it on the stock ECU, but once you start to turn up the boost, you will need to address EM...
I will be in SLC for Thanksgiving. If you are working on this by then, I will be happy to come by and wrench for a few hours. regardless, we should meet up...
Posted: Wed Nov 10, 2004 3:40 am
by azn2nr
yeha um, this stuff wont be here till spring ath the earliest if at all. i know the kid that has the stuff and it shouldnt be goin anywhere soon. im praying to god that i can get my dp off by thanksgiving so i can get my fmic piped.
though im thinking about it there are a few things i want to do before. ie
pump
na rails and injectors.
custom tbe
standalone
touq converter rebuild for higher stall.
that and id need an engine stand, time and space. bascily if i get all that stuff and i still want to pursue building the engine further then ill swap the heads. i was just wondering if at any time it would be worth it. i should also say my target is 300 whp or mid 12 whichever comes first.
