Differential Protector Producing Difficulty
Posted: Sun Nov 14, 2004 4:18 am
I stupidly bought the Legacy diff protector (B0310LS001) and it will not fit. The front requires some trimming, but that's not a big deal.
The rear will not fit onto the rear horizontal studs, because the rear frame crossmember gets in the way. The crossmember has a lip that sticks out (rearward) about a half inch, preventing the protector from sitting flush with the vertical surface of the crossmember.
I can't bend the protector around the lip, because this will shorten it, and then it won't reach the front studs. It'd be tough to bend anyway.
If the rear studs were longer, this lip wouldn't be an issue.
Maybe using the Forester diff protector (B031SSA000) would be correct?
Has anyone fitted this protector or solved a similar mounting problem?
