ECU pinouts
Posted: Tue Nov 16, 2004 10:50 pm
by bluesubaru
I have a 95 Legacy L, I know not a BC or BF. But I need to know if the ECUs are the same in 94 as they are in 95? The wiring diagram I have looks the same, but the wires dont match up. The production date is 10/94. Any help, I already tried ravensblade.com.
David
Posted: Tue Nov 16, 2004 10:56 pm
by JasonGrahn
I curious.
Why?
Posted: Tue Nov 16, 2004 11:08 pm
by professor
A production date that late would be a '95 BD/BG depending on sedan or wagon. Usually auto maker take shut-down in July, August or September at the latest to change models, especially with a big body change-over.
The ECU shows up as a separate part number with any source I can access. The wires not matching up would certainly add credence to that theory.
Posted: Tue Nov 16, 2004 11:17 pm
Right. The 95 ECU is very different from the 94 ECU. Actually, the 95 ECU is different from the 96 ECU too.
Why?
Posted: Wed Nov 17, 2004 1:09 am
by bluesubaru
Greddy Emanage, I have these here
http://www.ravensblade-impreza.com/modi ... 22ecu1.jpg
which is for a 97, but shares the same 2.2L engine.
But I still wasnt sure so I bought the online service manual. It looks exactly the same. I also tried calling dealer so I could take a quick peak, they said they cant show me their manuals.
The problem is my ecu doesnt have wires going to the pinouts I need. The wires on the pinout arent there on my ecu location. So I am confused.
Posted: Wed Nov 17, 2004 2:23 am
The 95 wiring is different from every other year.
I researched it a while back... Let me try to dig it up. If I haven't posted it in a couple days, PM me to remind me.
Posted: Wed Nov 17, 2004 2:37 am
by bluesubaru
I appreciate it vrg3, I guess it would have to be a 94 ecu, but who knows.
Posted: Wed Nov 17, 2004 3:52 am
Oh wait! You need the pinouts for a 94?
You need to pay more attention to the sticky posts in this forum. ;)
http://www.graphics.cornell.edu/~v/ecupins/
Posted: Wed Nov 17, 2004 4:51 am
by bluesubaru
Yeah I saw that way back. My ecu doesnt look like that.
this is what it looks like, but it doesnt match up wire for wire on my ecu.
Posted: Wed Nov 17, 2004 5:04 am
Uhhh... You sure your car is a North American 1994 model? Cuz 1995 was the first year to use that connector. And in 1996 they completely changed the pinouts.
Posted: Wed Nov 17, 2004 5:47 am
by bluesubaru
I can send you pics if you like. I am pretty sure it is North American.
I use the diagram to look for example to look for my RPM (engine speed output) wire, get the pinout number, go to my ecu, and no wire goes to there.
What does 96 look like?
Posted: Wed Nov 17, 2004 3:52 pm
by professor
If you car is US model the VIN will start with a "1" or "4".
If '94 the 10th VIN number digit will be "R"
If '95 the 10th VIN number digit will be "S"
this is true for most makes although the position of the year code for some manuf's does vary slightly.
It is good to take a code key with you when looking at used cars, dealers will sometimes bump the year forward in unscrupulous attempts to raise the value, and false VIN numbers don't fit the key sometimes.
Subaru should have been producing north american BD/BG in 10/94, as the body had been in production for other markets for a year already, and November would be way late to be making '94's.
Posted: Wed Nov 17, 2004 3:54 pm
Ohhh... Wait, I got confused.
Yours is a 95 model year car. It's a BD/BG. It was just manufactured in 1994. Okay.
I'll get you the pinout information.
The 96 ECU uses the same connector but has completely different pin specifications. I believe they stuck with more or less the same layout then for several years until the connector style changed again.
Posted: Wed Nov 17, 2004 5:56 pm
by bluesubaru
My ecu must be a 96 then or something. Becuase the pins have to be different. Nothing matches up. If you can get me a 96 ecu diagram I can check for sure. The 94 Pins arent it, my 95 pins look right but wires are wrong, so a 96 has to be it.
Posted: Wed Nov 17, 2004 6:34 pm
A 96 ECU won't work in a 95 car though.
Where are you getting your 95 pinouts?
Here are the pinouts from the FSM for 95:
http://www.graphics.cornell.edu/~v/pics ... inouts.png
I think I remember there being some slight errors, but I don't know for sure. When I find my researched pinouts we'll know.
Posted: Wed Nov 17, 2004 9:53 pm
by bluesubaru
Yeah this looks like it, and the pints are different to.
I was getting my points from ravensblades site. It was for a 97 Impreza 2.2L, but figured it shared the same engine it might share the same ecu.
Then to be sure, I bought an online service manual for my exact 95 Legacy, and it gave me the same pinout/diagram as ravensblade.
But this looks right thanks
Whare did you find it at?
Posted: Thu Nov 18, 2004 12:56 am
by bluesubaru
the link a few posts up. Ravenblades site.
and an online service manual I purchased.
Posted: Thu Nov 18, 2004 1:15 am
Hm. That online service manual is flat wrong then. You should ask for your money back.
Just so I know to avoid them, who sold you the manual?
Those pinouts I posted are scanned out of a factory Subaru service manual. They're included in Mitchell's electronic service manual that many garages subscribe to.
Posted: Thu Nov 18, 2004 6:05 am
by bluesubaru
alldatdiy.com
its a one year registration for like $25. I was referred to it by a friend. I emailed them a day or two ago telling them the scan had to be wrong. I am waiting on a reply now.
Thans you for the scan. I looked at my ecu and it matched up great. My car always suprises me somehow.
