WRX coilovers.
Posted: Sat Nov 20, 2004 11:10 pm
by BAC5.2
Coilovers for a GD will work properly with our rear suspension, right? I don't see any reason why they wont :)
Just wanna make sure, I found a KILLER deal on a set of coilovers that i am really interested in, but I wanna double check.
Just gotta find out how much to rebuild them...
Posted: Sun Nov 21, 2004 6:04 am
by THAWA
what are you using for top mounts? second gen doesnt fit in first gen: http://bbs.legacycentral.org/viewtopic. ... 2432#82432
Posted: Sun Nov 21, 2004 9:13 am
by BAC5.2
They come with pillowball upper mounts.
The fronts will fit, no problem (all EJ mounts are the same).
But it is the rears that I am concerned about.
The setup is the HKS HipermaxII's.
What is the difference between GC and GD rear top hats?
Posted: Sun Nov 21, 2004 9:36 am
by THAWA
i think the bolt pattern is different.
Posted: Mon Nov 22, 2004 2:26 am
by Yukonart
THAWA wrote:i think the bolt pattern is different.
I think Hardy's right. They changed something about it so you can't even fit them up there if they aren't for the right chassis.
Posted: Mon Nov 22, 2004 3:17 am
by BAC5.2
This is what I got back from NASIOC:
"they have a cup/spacer on the bottom of them whereas the GC do not"
I asked if the bolt spacing was the same, but haven't gotten a reply yet. I think it just must be the spacing, and the part number difference for the GC/GD has to do with the front spring rates being different, more than the rear mounts being different. I'd like to really know though. I need some definate answers ASAP.
Posted: Wed Nov 24, 2004 1:45 am
by NuwanD
you'll need tophats as the wrx bolt spacing is different, also beware that the rear suspension of the GD WRX is taller (ie' the strut body is longer) than that of our legacy and the GC imprezas. You can get around this since the coilovers are height adjustable, but if the height isn't adjusted seperately from the spring pre-load it may be a PITA... coilovers like JIC FLT2a (or something like that name) have independant height and spring preload perches
Posted: Wed Nov 24, 2004 6:29 pm
by JasonGrahn
Taller strut would mean that you need to adjust it lower to get the correct ride height for the car... I'm curious if you'll be adjusting it too low; ie, you'll be going lower then the working range of the strut.
hmmmm...
shoulda taken up on the H&Rs. :P
Posted: Wed Nov 24, 2004 6:41 pm
by BAC5.2
It shouldn't be a problem. The GD struts aren't significantly longer, and I'm not trying to slam the car. I'll be within the range of adjustment. I want the rear to stay at the height it's at right now, and if my buddy could tuck tire on his WRX then I'm sure I can get the height I desire without any ill effects.
Jason - If they don't work out, I'll sell them and pick up your setup if it's still available.
Edit: can someone measure their strut. From the top hat base to the bottom of the strut. I'd like to compare to stock without ripping apart my suspension first.
Posted: Wed Nov 24, 2004 6:51 pm
by JasonGrahn
If you're going to do measurements, measure both loaded height and extended height.
Posted: Wed Nov 24, 2004 6:55 pm
by BAC5.2
Good call. I'm looking to just get the extended height right now.
The coilovers I am looking at drop a WRX already, so it should probably be equalivent to stock in terms of overall height.
