Apparently it isn't getting fuel.....
Posted: Tue Nov 23, 2004 7:01 pm
by IronMonkeyL255
Apparently, my engine isn't getting any fuel.
I pulled the outlet hose from the fuel filter and turned it over and no fuel came out.
I haven't tried it with the inlet hose yet.
I may have to replace the fuel pump.
If I do, is there a good, relatively inexpensive upgrade for our pumps?
Posted: Tue Nov 23, 2004 7:07 pm
by tris91ricer
get the walbro. people here have, and love them.. most likely worthwhile, since you DO have a turbo.
Correct me if I'm wrong, someone, but i think it's the WRX -341 pump that works for ours..
is that right?
Posted: Tue Nov 23, 2004 7:36 pm
by IronMonkeyL255
Is it straight-up drop-in, or just about?
Got a site that has it so I know just what to look for?
anyone know how much a replacement regular fuel pump would be?
Posted: Tue Nov 23, 2004 7:48 pm
by tris91ricer
dunno.. but the walbro runs about $80-$85.. not too bad.. OEM, which DOESN'T flow up to 255lph is probably somewhere different...
Yes, its a drop in, if you get the right model.. otherwise, there's some wiring issues.. ask Douglas.(douglasvincent) or even Phil, BAC5.2
Posted: Wed Nov 24, 2004 3:01 am
check the fuel pump connector under the seat and verify you have power.
Posted: Wed Nov 24, 2004 3:47 am
by tris91ricer
The exact part number is GSS341, I did the searching for you.
Look in the Vendor Garage, and see if you can get your fuel pump AND support LegacyCentral members!
