tuning
Posted: Thu Dec 23, 2004 5:59 am
by bluesubaru
what did you all use for simple tuning. By that I mean something to read and modify your air/fuel ratio. I heard that a apexi turbo timer can be made to read the oxygen sensor voltage, and by that you can tune off of that.
What else have you all used?
David
Posted: Thu Dec 23, 2004 6:42 am
by BAC5.2
Tune by wideband O2 and EGT.
Ideally, if you don't know what your doing, you might want to let a pro help you.
There's probably a TON of books on the topic of tuning.
Posted: Thu Dec 23, 2004 6:46 am
by bluesubaru
i have egt, it wors okay, but I have heard it is not accurate enough.
I read can read the o2 sensor and use that to make adjustments. I dont have to make a hole for the new o2 sensor, I can just read off the one I have now.
Posted: Thu Dec 23, 2004 7:52 am
by BAC5.2
The one you have now is probably a narrow band O2 sensor. Not very useful for tuning. Low resoloution. EGT and Wideband with a wideband tuner is how people road-tune SAFC setups.
What exactly are you tuning though? I assume an SAFC or the like.
If you have a standalone ECU, you should just tune with the software given. I'm unfamiliar with tuning a standalone ECU, as every one is different. I will hopefully have a better grasp of tuning EMS in the near future though.
Posted: Thu Dec 23, 2004 4:47 pm
by bluesubaru
its for my emanage
i have nothing yet, just my egt, but i want more accuracy
Posted: Thu Dec 23, 2004 6:10 pm
by 91White-T
AEM makes a A/F gauge that reads off a wideband, and shows the ratio as well as the color. EGT is good, you should be able to do pretty well with that, but a wideband O2 is definitely what you want also.
Posted: Thu Dec 23, 2004 6:12 pm
by BAC5.2
You can mod Autometer A/F gauges to read wideband.
www.fastwrx.com sells them (MachV).
Wideband is expensive though (to the tune of around $300).
Posted: Thu Dec 23, 2004 7:40 pm
by bluesubaru
yeah i was trying to avoid the $300 mark, and having to make another hole in my exhaust for the wideband 02 sensor
Posted: Thu Dec 23, 2004 7:57 pm
by BAC5.2
Do you want it tuned, or do you want it tuned correctly?
There is a mantra with modding, ESPICALLY with aftermarket turbo setups: "You gotta pay to play"
Posted: Thu Dec 23, 2004 8:47 pm
You don't need to cut another hole. You can put the wideband sensor in place of your stock sensor. Many (maybe all?) wideband oxygen sensor controllers have a simulated narrow-band output that you can feed to whatever still needs the narrow-band signal.
Posted: Thu Dec 23, 2004 8:52 pm
by BAC5.2
If you are running an E-Manage, you shouldn't even need the narrow-band.
It should be able to take full advantage of the wideband. I know most real standalone's can simply take advantage of the wideband sensor, and use it for some SUPER efficient closed look systems. Bonus feature is that fast standalone's can likely read the O2 sensor pretty quickly, so you can be in closed loop longer, which is better for just about everything. I would LOVE to have the system be fast enough to run closed loop at WOT. That would make things SO much more safe, I think.
But Vikash is right, the Wideband controller required to use the wideband O2 sensor, can lower the resoloution of the sensor to be compatable with anything that might need a stock narrow band setup.
Posted: Thu Dec 23, 2004 11:04 pm
by bluesubaru
so my route in purchasing is...
I just read this to
http://www.sr20forum.com/showthread.php ... r+air+fuel
I read other forums to get others opinions
Posted: Thu Apr 28, 2005 12:39 am
by greg donovan
BAC5.2 wrote:You can mod Autometer A/F gauges to read wideband.
which A/F gauge there is the one that reads wideband?
Posted: Thu Apr 28, 2005 12:42 am
by greg donovan
Posted: Thu Apr 28, 2005 6:30 am
by azn2nr
http://store.yahoo.com/fastwrx/plxdewio2se.html
this one. it has narow simulator. this is actualy the only ones that ive seen that has it. aem uego at least doesnt. the zitronic might but with display its a little more than the plx
Posted: Thu Apr 28, 2005 4:41 pm
by bluesubaru
I think no matter what, to do it right and accurate. A wideband from any company will cost us.
Posted: Thu Apr 28, 2005 10:46 pm
by greg donovan
well it looks like the wideband controller is the expensive part.
a wideband sensor for the plx kit is only 70 dollars. while the kit is 300 w/out a display and 350 w/a display.
and the gauge converter for 45 dollars is the piece needed so you can use a narrow band gauge.
dont see the point of buying the converter though. a sensor and controller w/display is the same price as the sensor and controller w/out display and the converter when all is said and done. and then you still have to buy the gauge. unless this thing does something to make the stock ECU happy. and if it were that crucial you would think it would be part of the kit.
Posted: Thu Apr 28, 2005 11:26 pm
by bluesubaru
yeah exactly
stuck either way
