My $7.50 AFC
Posted: Tue Dec 28, 2004 5:40 am
First off, Thanks vrg3!
Some wire, some bullet connectors and a 50K potentiometer.
As some of might know, and for those who don't, I installed 370 cc injectors in place of my 270 cc injectors because i was running horribly lean under boost. However, this now gives me the opposite result of running incredibly rich so that my milage sucks and when under boost, the engine bogs horribly as soon as I get about 5250 rpm and higher.
So I had to trim fuel or trick the computer to trim fuel. And I also had to figure out what signal my MAF sensor was sending to the ECU.
So I hooked up the MultiMeter to the MAF signal wire. Idle started at .8ish and at WOT I would get max 3.4 volts. Under boost I would max out at about 4.8 volts. Important is that anything over 4.4 volts or so would induce the dreaded bog.
Oh yeah.
This is done on a 1990 2.2 NA Legacy. I cut the #4 signal wire near the MAF and ran two wires into the car. I marked the line connected to the MAF as the "IN" line. I took the 50k potentiometer and soldered two wires to it, one of the wires is also soldered to the middle prong, ie wire 1 is soldered to both prong 1 and prong 2. wire 2 is wired to just prong 3. Then the "IN" line is connected to wire 1. The "OUT" line is connected to wire 2.
I connnected a multimeter to the #3 wire (ground) and #4 wire AFTER the potentiometer. This gives me the true reading going to the ECU. Then I can monitor the reading.
So I installed a 50k potentiometer from Radio Shack. This allowed me to trim the signal about 10% or so. At a 3500 rpm cruise level, I can turn the knob back and forth and "feel" the break point from too lean to just right. I can also do this under boost by having it read too "rich" at anything over 5000 rpm and crank the knob toward lean and instantly have the bog dissappear.
I have heard this might advance timing some, but since I run premium all the time, I am not afraid of knock.
And as it is, big difference. Not alot more power overall, but now I can get that extra power from 5000 to 6000 rpm which, as we know, is very important to the ego.
Oh yeah.
