New SC step pulley went to crap, so far.....
Posted: Fri Dec 31, 2004 7:26 am
Arrgghhh!!
I have a small lathe so I can make my own pulleys. Since it is small, it takes awhile but since it is my time, not my money, it is cheaper to do it this way. Usually.
I spent about 15 hours total yesterday and today making the new step pulley for the supercharger, uninstalling the old setup, purchasing and re-cutting a new mounting plate for the supercharger, and then installing, re-milling and reinstalling the step pulley and than reinstalling the supercharger on the new mounting plate. All to have it go to shit.
The step pulley was made to boost the supercharger rpm from 1-2 to 1-2.5. Which should give me almost 2 psi extra boost, maybe a little more. The step pulley was a 2” pulley and 2 ½” pulley. To make the pulley, I started with a nice 3” diameter chunk of aluminum. The concept is simple, but the reality was a little different. This is because the power steering pump shaft is splined. Making a splined pulley is near impossible unless you do what Subaru did, which was take a splined section, weld it into a chunk of metal, and turn the resulting piece. I didn’t have this option. So instead I cut out the steel section from the stock pulley, turned it round and clean, and then turned a mating hole into the aluminum pulley and inserted.
Here was the problem.
The freaking thing can’t be welded in. So I tried drilling out the pulley and inserting pins and set screws. Didn’t work. Crap. Then I drove my van home.
I guess I have to spend money after all. Hopefully I can get it somehow permanently install tomorrow and then I can get the damn this running tomorrow night.
I have pictures, and will post them this weekend I hope.
