Im thinking my water pump?
Posted: Fri Jan 07, 2005 7:08 pm
by irishsetter
I have some coolant issues. I am not over heating but upon start up coolant trickle down from the top of the lower radiator hose where it goes to the engine. There are two small hoses on one side and one small hose on the other. They all seem to be fine. I can not see where it is coming from is this the water pump location? Is there a weep hole for when the pump bearings go? Can anybody help?
Posted: Fri Jan 07, 2005 11:30 pm
by evolutionmovement
Yes there's a weep hole for when the bearing seal is compromised. Probably is your water pump.
Posted: Fri Jan 07, 2005 11:50 pm
by irishsetter
That suck, do know how difficult it is to replace.
Posted: Sat Jan 08, 2005 4:47 am
Not bad. Do the timing belt and cam seals possibly at the same time. There are plenty of threads on it and your luckily in a warm climate. I'd say an afternoon first time.
Posted: Sat Jan 08, 2005 7:42 pm
by irishsetter
Very cool thanks. Hopeful that will do the trick.
Posted: Sat Jan 08, 2005 11:15 pm
by entirelyturbo
irishsetter, if push comes to shove, bring it down to Orlando and I'll be more than happy to help you. Only about a 2 hour drive.
Posted: Mon Jan 10, 2005 1:55 pm
by irishsetter
Cool thanks but I think there is only one way to learn and thats dive in head first.
Posted: Mon Jan 10, 2005 6:44 pm
by entirelyturbo
No problem, if you still need help, post away...
