Laurel's Relatively Unsuccessful AWIC Install Meet /56k
Posted: Sat Jan 29, 2005 7:59 pm
by LaureltheQueen
Okay, here's the first wave of photos. Tristan's hanging for the rest of the weekend to see the install through to the end(hopefully) and check out autocross on sunday, so there'll be more photos showing up probably sunday night
Art's been through the bumper beam trauma, got his JDM fogs in this morning
See Hardy!!! I really am doing engine work... does removing the chimney count?
oh well, at least I looked cute.
92 Le-Turbo-SS
91legacy_Sleeper
This one's for jake
Waiting for Art to come back from the dealership with a diagram
mmm, cookies
Looks cool?
Really Excited (my friend Craig on left, Reed, AWD_Addict on right)
Bumper removal
Arturo being a gentleman and changing my sparkplugs
blang blang
The evil fins we were up against
The guys showed them!
Art and our friend Elliot
Good illustration of the jack point
Triumping over the removed bumper cover
Ghetto wiring job for my fogs, we'll be fixing that too
Flattened bumper reinstalled, radiator too thick
Radiator too wide to clear the hood latch thing
Can't turn it sideways, too tall
Thanks guys, you've all been lifesavers, and thanks Vikash, I promise I didn't mean to make you think I'm stalking you, I just respect your opinion most.
Posted: Sat Jan 29, 2005 8:10 pm
if you take the hood latch out, will the radiator fit, or is it still too big?
Posted: Sat Jan 29, 2005 8:12 pm
by LaureltheQueen
it may, but the hood latch piece is structural
Posted: Sat Jan 29, 2005 8:46 pm
by evolutionmovement
Ah, don't worry about that structural stuff, just move to hood pins!
Art, you look like Andy Garcia in the spark plug-changing photo. "Did I ever tell you about Jimmy the Saint from Flatbush?" Is that huge black box full of tools? Mmm, tools ...
Posted: Sat Jan 29, 2005 10:09 pm
by dzx
are those snickerdoodle cookies?
Posted: Sat Jan 29, 2005 11:23 pm
by jake15
looks like fun... to bad i couldnt make it
oh well, looks as if you might be doing it again if you dont finish this weekend
is they hood latch in the way of getting it down into place? or just in the way in general? if its just in the way of getting it down, take off the bumper beam or the hood latch and slide it into place. it looks like there is enough room behind the bumper beam for the i/c radiator. if not, do some creative cutting of the beam. hehe
Posted: Sun Jan 30, 2005 12:59 am
by LaureltheQueen
there's no way i'm cutting up my hood latch beam. Went to an auto parts store today and got a heater core or heat exchanger thing from a gm car, looks as though it'll fit like a charm.
Got the plugs changed just a few minutes ago and there's a noticable increase in revving speed. or it may just be me pretending the car's faster in my head. either way, i'm happy with it.
Art'll be back soon from Home Depot, getting stuff to make brackets for the radiator. We're likely not going to get it done this weekend. Gonna take care of the water side of things so I can get the bumper back on, and the car drivable. I have no real need to have the air portion going at this point, i wont have the $$ for a downpipe for another few months, and can't up the boost til i get a downpipe, I also need access to a boost gauge for about a day to get the boost set correctly as well. urgh
money pit
Posted: Sun Jan 30, 2005 1:08 am
by NuwanD
I thought you were ditching the A/C system? In which case wouldn't the heat exchanger fit where the a/c rad went?
Just an idea, cause the a/c is still there in the pics.... good luck with the rest of the install
Posted: Sun Jan 30, 2005 1:41 am
by THAWA
Wow, looks like you guys had a nice conglomoration of people
Good to see ya gettin dirty.
Posted: Sun Jan 30, 2005 4:35 am
Is the hood latch itself in the way, or the hood latch beam in the way?
Posted: Mon Jan 31, 2005 3:20 am
by Yukonart
Josh. . . BOTH are in the way. . . but mostly the beam.
I'm trying to convince Laurel (since this will be her only car for a while) that the AC could probably be easily fixed with a used compressor (which Tristan has already offered to donate) as there's ZERO load on the engine when turning on the AC system. (Either the compressor clutch, or the compressor itself. Either way, the condenser is good, and should need only charging once a known good compressor is swapped.
Thanks, Steve. . .
Never been told I resemble Andy, but I guess that's a good thing.
Taking the beam in tomorrow to where our roommate, Tim, works. Many air tools (I need only a compressor to get mine going. . . guess what I'm buying in a month or so) and we're going to cut off ALL the bumper flanges on the driver's side. Maximum airflow to the heater core would be preferred. Then I'm primering and painting the back of the beam.
The heater core doesn't weigh much, but should be very securely-attached, so Tim offered to help me custom-fab a bracket for it while Laurel's got my car at school, tomorrow.
Tuesday, we hope to have the heater core mounted, the bumper back on, and the rest of the front end reassembled once we start the running of the water lines into the engine bay, just in front of the batter (where the water pump will eventually be placed)
I'll let Laurel elaborate on all this more once we've got a more detailed gameplan.
Posted: Mon Jan 31, 2005 4:15 am
by THAWA
get a JDM bumper beam yo. mad tyte!
Posted: Mon Jan 31, 2005 4:21 am
Art,
You'll need a new receiver/dryer when you recharge the ac system. It probably wouldn't hurt to flush out the system too.
Posted: Mon Jan 31, 2005 4:22 am
by BAC5.2
Art, I want that shirt. And Sonia = teh hawt.
Good luck on getting it all together Laurel. I'm proud of you for getting your hands dirty. Seeing the picture of the bumper beam helps me a lot
You two's needs to get onlines!
by BAC5.2
Might as well convert to R-134a while your at it.
Posted: Mon Jan 31, 2005 4:42 am
by Yukonart
Indeed, Josh. . . we plan to do it all right, if we do it at all.
And yes, Phil. . . if we fix, we'll convert to R-134
And thanks! Here's a shot of me today leaving the autocross right before work:
Posted: Mon Jan 31, 2005 5:29 am
by BAC5.2
Good LOOOORD those things look so hot. Did you use a factory JDM switch?
Get online! AHHHH!
Or are you at work? In which case, when do you get home?
Posted: Mon Jan 31, 2005 5:41 am
by Yukonart
The JDM kit (as does the USDM kit) comes with switch, lights, bulbs, mounting brackets, bolts, and painted surrounds. It's literally a plug-and-play installation (once you take care of the bumper beam being in the way of the JDM monsters). The cars all come pre-wired for factory fog kits.
Yeah, I'm at work, Phil. I'll get online around midnight our time after I get home from work, though. If Laurel's not got a ton of homework to do before tomorrow morning, she'll likely be on in a bit.
Posted: Mon Jan 31, 2005 5:51 am
by BAC5.2
Blast, I'll just PM you and steal you from teh work.
Posted: Mon Jan 31, 2005 5:53 am
by Yukonart
BAC5.2 wrote:Blast, I'll just PM you and steal you from teh work.
