Page 1 of 2
Flashing seat belt light
Posted: Mon Sep 08, 2003 9:54 pm
by georryan
Hey, the other day on my drive home I noticed that my seat belt light didn't go out. Instead, it was flashing on and off. I unplugged the passenger belt and it beeped like it was sappose to, but when I unplugged my driver side auto belt it didn't do anything. No noise, and the light kept flashing. It still works fine; when I open the door it slides to the otherside to let me out. Has anyone else had this problem? What was it? Is it some sensor?
-Ryan
Posted: Mon Sep 08, 2003 11:50 pm
Posted: Tue Sep 09, 2003 12:35 am
by georryan
Thanks a billion Josh, I'll look into it soon. I had NO idea our cars had a seat belt memory. If I clear the ecu will this be cleared also? I have to clear it after taking out the snorkus still.
Posted: Tue Sep 09, 2003 1:06 am
by georryan
Were is the number 22 fuse?? It isn't under my hood, is it under the stearing column? Those aren't numbered on my car, and nothing is labeled as seat belts.
Posted: Tue Sep 09, 2003 2:18 am
by ciper
:lol:
Learn something new everyday, a seat belt computer!
Posted: Tue Sep 09, 2003 2:37 am
by georryan
That's what I thought! :)
No takers on the number 22 fuse?? I'm still looking for it. :)
I'm going to feel real silly it is in an obvious place......
Posted: Tue Sep 09, 2003 6:36 am
by LaureltheQueen
those seatbelts are the devil. There's been many-a-oil change when i've almost been decapitated due to those damn things.
Posted: Tue Sep 09, 2003 2:06 pm
georryan wrote:That's what I thought! :)
under driver's kick panel
http://www.main.experiencetherave.com:8 ... er/118.jpg
http://www.main.experiencetherave.com:8 ... er/119.jpg
Some may know, but for others,
Two very great resources I've put together
All the scans I have done from my manuals.
http://www.main.experiencetherave.com:8 ... nual_scans
Also, The entire 1990 owner's manual scanned, and there's three options, a condensed pdf version, zipped pdf, and individual images for each page.
http://www.main.experiencetherave.com:8080/owner/
Posted: Tue Sep 09, 2003 2:27 pm
by stant093
hey thanks for the link josh...got a few things to inquire about in that manual...i appreciate it!
Sam
Posted: Tue Sep 09, 2003 7:52 pm
by ciper
LaureltheQueen: :lol: I know exactly what your refer to.
Posted: Tue Sep 09, 2003 8:14 pm
Laurel and ciper, I don't get it... How do you get your neck in the path of the seat belt during an oil change?
Posted: Tue Sep 09, 2003 8:21 pm
by georryan
You start the car real quick or to let the oil cycle through the filter, and open the door as you are leaning forward. Or you open the door just after you've pulled the hood release, yeah I've had similar situations happen to me. :)
Ok, a question on that fuse again. According to the manual the number 22 fuse is under the hood marked as sub fan. Well I pulled that with the ignition off as it says, I've even run the car with it out and it didn't fix or even kill my flashing seat belt signal.
It isn't even really giving a real signal, it is just doing quick flashes, no long flashes. So in essence it is like 1 repeatedly or 9 or any other single digit number, because it doesn't pause to signal a break.
Now Josh, you mentioned that it was behind the kick panel under the steering column. I Looked in that fuse box and don't see anything marked as a seat belts, also there is no numbers on those. Is there a second fuse box on the driver's side? I haven't found any record of one. Sorry guys for the constant questions, I just can't figure out how to clear this thing. I've been going over the paper work which states to clear the memory by pulling the number 22 fuse with the ignition off. That hasn't worked though, so I'm wondering it is a different fuse.
Posted: Tue Sep 09, 2003 9:58 pm
by ciper
Or with the door closed you stick your head in to turn the key and when you do the seatbelt goes back and wraps around your neck :lol:
Ive done that so many times, you'd think I would have learned by now!
Posted: Tue Sep 09, 2003 10:04 pm
by georryan
hahahaha, I don't know if my car will let me start it with the clutch up, I think I have to depress it before it will turn over.
Posted: Wed Sep 10, 2003 12:56 am
by ciper
If you turn the key to the on position without starting it, say to turn the radio on while working it will get you too!
Posted: Wed Sep 10, 2003 1:11 am
my bad, it is the fuse box in the engine bay.
As to why when you pull that fuse the light still blinks, I'm not sure.
Either the manual is incorrect in telling you what fuse to pull, or something is not right.
I would suggest pulling the codes from the auto seat belt connector. There is a little connector under the dash somewhere. Unfortunately I have had no luck in locating it. However I haven't searched super hard for it.
Posted: Wed Sep 10, 2003 1:29 am
by georryan
Thanks for the help Josh. I saw that connector in one of the pages you posted. I'll look into it. Thanks.
-Ryan
Posted: Wed Sep 10, 2003 1:31 am
by georryan
Guilty of that also. :)
Posted: Tue Sep 23, 2003 3:08 am
by georryan
Whahoo! fixed the stinking blinking light. I found out that you actually have to connect the two connectors so that you can read the error, only then can you clear the memory. The connector is hard to find and it was black on my car, just over the accelorator pedal for anyone who ever gets that problem again. It's nice not to have that thing blinking anymore.
-Ryan
Posted: Tue Sep 23, 2003 3:21 am
yes.....I was trying to help a friend with hers...and told her she needed to find that little black connector to diag the codes......but I could never really find the connector.......so neither did she.....
Posted: Tue Sep 23, 2003 4:29 am
by georryan
Yeah, find that black connector, and follow the wires back. Wrapped up in electrical tape, you'll find the other connector looped back through the tape. When I first saw it I was like "crap, I pulled it out of the back of a connector!" It looked like it belonged somewere else. That was it, though. You shouldn't have much problems now. :)
Posted: Tue Sep 23, 2003 11:27 pm
any chance you could get some pics of where that connector is, or of the connector?
Posted: Wed Sep 24, 2003 5:16 pm
by georryan
Yeah I'll try and get some tonight.
Posted: Wed Sep 24, 2003 11:45 pm
coool, thanks
Posted: Thu Sep 25, 2003 5:45 am
by georryan
Here's the pictures. Sorry they are large. I haven't quite figured out my friend's digital camera yet. :)
http://cs.wwc.edu/~georry/Wire1.JPG
http://cs.wwc.edu/~georry/Wire2.JPG
Although it doesn't look like it, the little connector and the bigger connector both go to the same wiring group, if that makes sense.
In the first photo, the bigger black connector can be seen just above the blue connections. The red and white wires going to it are just above the blue connector.
