AWIC GM Heater Core Installation
Posted: Mon Feb 14, 2005 11:36 am
by Yukonart
More for reference than anything else, I'm posting pictures of the heater core installation Laurel and I performed on her car while her front bumper was off.
We'll get the exact part number shortly. ;)
You all remember how I had to pound the shit out of these retarded flanges on the bumper. . . .
Well, once pounded so the radiator could fit, they were in the way of the airflow to the very radiator we pounded them over to fit. We cut them all off using an airsaw and cutoff wheel. (Not shown) I then primered then painted the cut areas to prevent any possible corrosion.
Here you can see that they just had to go. .
Overall picture of the heater core (which was determined to be an almost perfect fit for this application)
The outermost markings are the ones I used to cut the ends of the water lines to a manageable length:
Lines cut to length, and heater core ready to install:
Here you can see that we installed the heater core as close to the center of the car as possible to not only maximize airflow, but also to leave as much room as possible to fit the water supply hoses to the radiator. (Note the two convenient holes under where the driver's side headlight housing mounts to run the supply and return water lines through.) ;)
. . .and clearcut shots of the snug fit the heater core is behind the bumper beam. . . .
Posted: Mon Feb 14, 2005 4:38 pm
Neato burrito!
Do you know what car the heater core was meant for?
Are heater cores designed to withstand exposure to the elements?
Posted: Mon Feb 14, 2005 5:19 pm
by BAC5.2
Oh man, I can't wait to take my bumper off and start cutting into my bumper beam.
That's really awesome guys! Good work!
Posted: Mon Feb 14, 2005 6:17 pm
by AWD_addict
You guys sure showed those flanges. Looks good too.
Posted: Mon Feb 14, 2005 9:56 pm
by LaureltheQueen
those flanges are pieces of shit. :mad:
Posted: Tue Feb 15, 2005 1:13 am
by Yukonart
LaureltheQueen wrote:those flanges are pieces of shit. :mad:
Correction. . . they can lick my balls.
(Just like double-wishbone suspension)
Posted: Tue Feb 15, 2005 2:02 am
by 92 Le-Turbo-SS
Bravo Art, I'll be using your knowledge in the future with a complete parts list of the whole project so I can do this all in one day/evening without any unnecesary trip to the auto store.
Cool!
Posted: Tue Feb 15, 2005 2:57 am
by Yukonart
I think the part that'll require the most time is definitely the bumper beam hack job. After having taken an airsaw and cutoff wheel to it, I realized that the pounding I did to those flanges was very necessary to make the cutting of them far more effective, and easier.
Add to that, grinding smooth the cut areas, primer and paint . . . all of which I did, and tried not to rush.
I'd just plan a full weekend of work if you want to keep your car down for a minimum amount of time.
Day 1: Removal and "augmentation" of bumper beam, perhaps install intercooler and air ducting while finishing the bumper's primer and paint process.
Day 2: Attaching of the radiator to the rear of the bumper beam, replacement of the bumper beam, running of the water lines and installation of the water pump.
Granted, we know a bit more about all this than when we started, so I'm making an educated guess on the time needed to get it all done. ;)
Posted: Tue Feb 15, 2005 3:57 am
by TheSubaruJunkie
Hey art. Maybe think about drilling more holes in that bumper beam to allow better airflow through those 2 beams that cover the radiator. Looks like it covers almost half of the IC's radiator.
The install is looking great tho. Have you mounted the AWIC yet? Cant wait to see it finished.
-Brian
Posted: Tue Feb 15, 2005 5:40 am
by Yukonart
Thought about that, Brian. . .
But the metal that makes up these bumper beams is friggin' THICK!!! :(
Posted: Tue Feb 15, 2005 7:28 am
by LaureltheQueen
also, there's no point in it, the bumper cover covers everything else up. If you were to drill holes upwards and down at an angle it would just whistle and get shit stuck in it
Posted: Tue Feb 15, 2005 9:19 am
by MY92
What is the size of that puppy compared to the factory awic radiator core?
Posted: Tue Feb 15, 2005 9:51 am
by LaureltheQueen
there's the adm one. :)
I know the GM one is considerably smaller, but a little radiator is better than no radiator. I can always get another if I feel inclined to hook 2 up and tear my bumper off again
Posted: Tue Feb 15, 2005 3:42 pm
In city driving, air/water intercoolers often work almost as well with the pump turned off as they do with it in.
And there are some Porsches with giant intercoolers mounted in the rear of the vehicle, where they get very little ambient air. They still work much of the time.
A lot of the time all you need is a big heat sink, not active cooling.
Posted: Wed Feb 16, 2005 10:56 pm
by MY92
Haha, you lot are like me. Hoarders
Posted: Thu Feb 17, 2005 6:10 am
by BAC5.2
How does the ADM exchanger fit in the ADM cars? What is different?
Posted: Thu Feb 17, 2005 6:43 am
by LaureltheQueen
the bumper beam as far as we know
Posted: Thu Feb 17, 2005 6:49 am
by Yukonart
Yes. . . just like ADM gets all the sweet Jspec cars . . . I'm sure they have Jspec (ie: bumper beams) attached to them. :)
Posted: Thu Feb 17, 2005 8:52 am
by THAWA
LaureltheQueen wrote:Image
What are you doing with this? Keeping it or selling it?
Posted: Thu Feb 17, 2005 8:26 pm
by Yukonart
Guess that depends on whether or not Jim can use it once he's got a JDM bumper beam.
Posted: Thu Feb 17, 2005 10:07 pm
by BAC5.2
What was wrong with cutting the bumper beam to fit?
How thick is the bumper beam? I'm gonna have to drill a few holes in it I think....
Posted: Thu Feb 17, 2005 10:41 pm
by Yukonart
BAC5.2 wrote:What was wrong with cutting the bumper beam to fit?
Nothing's WRONG with cutting it. . . it's just a royal pain in the ass. And even then, it's still leaving less space between it and the AC condenser than the JDM one probably is.
Posted: Wed Apr 20, 2005 1:18 pm
by mikec
Gonna bump this because I didn't see a part number mentioned anywhere.
Come on! Stop keeping that valuable information to yourselves! :)
