Symptons of a bad strut?
Posted: Tue Feb 15, 2005 12:45 am
So for a couple weeks now I will notice a small knock from the front passenger side of the car, near the wheel (the seperate rpm dependent knock is still present for those wondering, though it's definately worse in the cold). Alignment is still good and all the joints and tie rod ends all seem tight. I haven't had the wheel off the ground yet to really check the ball joint though. If I rock down on the front driver's side it dips, comes up and repeats once more maybe before settling. All nice and quietly. Now if I do this on the front passenger side it dips and damps out alright, perhaps a little longer than the other side, but it definately makes a small knock sound. Just once, and it's on the rebound from max compression. If I grab the coil I can 'shake' the assembly more than I can on the driver's side. Like I said I need to get it up in the air but it's supposed to rain for another couple days I think but as soon as I can I will. Any opinions?
Lee
Lee
