help on wireing
Posted: Wed Feb 16, 2005 2:26 am
by NICO
i am makeing a 95 impreza a turbo legacy, if i use a auto turbo legacy wireing harness to save on time and put a 5speed turbo motor and tranny in will the car be the same. no problems right just the auto car has to hook up with the ecu and the 5speed dosent.
Posted: Wed Feb 16, 2005 5:19 pm
Yeah, if you're putting a 5-speed transmission in you can use an auto Legacy Turbo harness. Just cut the wire going to the ECU's "transmission ID" pin.
Posted: Wed Feb 16, 2005 8:12 pm
by NICO
what wire would that be vrg3. its on the ecu side or near the plugs that plug in to the auto tranny
Posted: Wed Feb 16, 2005 8:26 pm
Posted: Thu Feb 17, 2005 2:42 am
by NICO
so un plug this wire B48.20 Transmission ID out of the ecu and tape it up. and everything will be fine but i am useing my 5speed ecu with the chip
Posted: Thu Feb 17, 2005 4:59 pm
There's no difference between 5-speed and automatic Legacy Turbo ECUs. The only difference is that wire. So, yes, disconnect the B48.20 wire and tape it up. I believe the wire is black with a white stripe.
Posted: Thu Feb 17, 2005 5:12 pm
by NICO
thanks vrg, cant wiat to drive this car.
