Front and rear GC strut bars for an N/A sedan- Front is on
Posted: Wed Feb 23, 2005 3:17 am
I bought some of the cheapo e-bay strut tower braces for about $75 total, shipped. The rear I got from a vendor called drivinggear, and the front from procarparts. I ended up buying from different places because neither of them wanted to sell both bars at the same time, and it allows me to compare them.
Procarparts had "40mm" bars, and regular bars, so for about the same price I decided to go with the 40mm. It's a pretty solid piece, although I don't have a nice cusco or STi bar to compare it to, so I don't really know. Same goes for the plates, although the drivinggear rear bar plates have better welds. The bars also have left-handed threads on one end, so turning the bar will adjust the length when it's installed.
The top is the 40mm front bar, the bottom is the rear. I should vacuum my floor.
Front mounting plate
Rear mounting plate. From what I've heard I'm going to need to grind some stuff or something for it to fit.
I bought STi takeoffs and a rear sway bar (18mm from a turbo), so I'm waiting to install it all at the same time. Those UPS bastards had better find my missing strut. I still test-fitted the fronts, and ran into a slight problem.
The tabs on the left mounting plate are crooked
You can see that they don't line up with the other plate.
Here's the view from the other side
At least the holes line up. I took some pliers and bent the tabs so they're pointing more or less the right way.
Seems there's another problem; an A/C line is in the way of the right plate. (money shot)
It might fit underneath, but I think I'm going to have to move the line or something. Any suggestions on that?
The bolts were another concern, as I'd heard the chrome plating or whatever they put on can flake off and jam the nut. The bolts for the rear bar didn't have this plating. I just went to the hardware store and bought new nuts and bolts.
I don't really expect to notice anything from the bars themselves, and wouldn't be able to anyway with all the other new stuff going on. I do imagine that they will reduce some chassis flex with the stiff suspension on my older car.
I can also see the benefit of buying a nicer, expensive bar. I imagine the welds would be better, and the construction and fitment would be more precise.
