Whiteline front lowering springs part number
Posted: Thu Sep 11, 2003 4:12 pm
by HomeSlice
i am in need of the correct part number for the whiteline lowering springs in the front. i have whitelines in my hand but i think i have the wrong springs or something because the top springs seats are way to big for the top of the spring. the part number i am holding is a c90-20066-
I thought the springs from the gc8 and the legacy where the same? could i have impreza springs or somthing>? did a search could not turn up nothing- i hope i just have to by just new spring seats..........
thanks,
jim
Posted: Thu Sep 11, 2003 10:11 pm
by b44jd
I'm here in Sydney, AUST.
Do you want me to phone Whiteline (i know the guys there)?.
Maybe first use the link and look them up OR send them an email (may take a few days to answer as it's friday here now).
http://www.whiteline.com.au/store/
What car/model/etc do u have?.
Let me know.
Cheers
John Dyer
Posted: Fri Sep 12, 2003 1:28 am
full catalogue
http://www.whiteline.com.au/docs/catalo ... a_full.PDF
d/l it and you can find out which ones you have.
Posted: Fri Sep 12, 2003 8:18 pm
by HomeSlice
jim from whiteline got back to me and told me the springs are for the impreza gc would the fit right on my bc?? thanks for the help guys
Posted: Fri Dec 05, 2003 8:57 pm
by eastbaysubaru
The plot thickens...
As Xmas is coming up, I'm planning on getting suspension as a present. Yeah! I looked on Whiteline's website for the correct part numbers before I go off ordering willy nilly. They're listing two different part numbers for the front springs. The springs catalogue lists the following:
70198 (front)
70369 (rear)
While the Applications brochure has these part numbers:
74502 (front)
70369 (rear)
So I'm stumped. Who's ordered these? If you have, what part number did you use?
-Brian
Posted: Sat Dec 06, 2003 5:22 am
answer on what I used is in the 5th post down
http://bbs.legacycentral.org/viewtopic. ... pring+part
Looking at their parts catalogue is weird....they've changed their springs.....looks like they have a different spring.....however If the ones I got lowers the car evenly....I'd question what the new one does.....unless it just has a lower spring rate.
Shoot whiteline's tech support an email. They have been very helpful when I talked to them. They should be able to give you the 411.
Posted: Sat Dec 06, 2003 10:42 am
by eastbaysubaru
Thanks Josh. I read the first part of that thread when searching, but didn't get down to your post with the actual part numbers :oops:
-Brian
