Pictures and notes of my on going swap project. *updated*
Posted: Wed Mar 16, 2005 2:32 pm
Here's a few pics of my on going project if anyone is interested. I'll update every once and a while.
http://www.thawa.net/gallery/albums/The ... .sized.jpg
The old
The replacement
Found some damage on the replacement motor.
The timing was off by 45 degrees too!
After a lot of cleaning, new cam sprocket, front and rear timing belt covers and timing belt.
With the Go Fast Bits Lightweight Underdrive Pulley
Old steering wheel
New steering wheel
Some random shots
Shhhhhh, she's sleeping
Another reason not to let Adam at Z1 Performance touch your car!
Those are GC8 springs with Legacy perches! The BJ Legacy was on those. Very dangerous.
*update*
Well, here's a few more pics.
The AC pulley tensioner was toast on the BJ engine so I swapped my good one over.
Swapped over my cam and crank angle sensors as well as my knock sensor. The BJ sensors were hacked to hell. F*@kin' Adam.
The knock sensor was a total bitch because Adam had the sensor installed on the bellhousing part of the block, over the flywheel
, and not in the proper location. Because of this, the knock sensor mounting point was totally foul. As a lot of you know it is very hard to access that spot so I did my best to clean it up and sand the area but I could only get it so clean. Hopefully it will work out ok and not haunt me.
I also had to swap over my IAC because the BJ's connector locking tab was broke.
The new one.
I also pulled the starter and the clutch fork rod.
I also cracked the the bolts that hold the tranny and engine loose as well as cracked the motor mounts loose.
So really I'm about done with everything I can do without actually swapping the engines around.
Swap party at my place! Who's coming?
OK, nobody showed up for the party except my buddy Nick, thanks Nick.
Here's a couple more pics. I got the engines swapped over but found out that my clutch is toast. I don't have the money to change it now so it looks like I'll be babying it big time for a few months.
http://www.thawa.net/gallery/The-swap/PICT0261
http://www.thawa.net/gallery/The-swap/PICT0259
http://www.thawa.net/gallery/The-swap/PICT0262
I also went to install the Walbro 255 FP that came off the BJ Legacy but holy crap, the thing is totally fried!
http://www.thawa.net/gallery/The-swap/PICT0255
http://www.thawa.net/gallery/The-swap/PICT0257
http://www.thawa.net/gallery/The-swap/PICT0258
That's it for now, I'll post more as I go.
The old
The replacement
Old steering wheel
New steering wheel
Some random shots
*update*
The new one.
