'96 Heads
Posted: Sun Mar 20, 2005 5:19 pm
by evolutionmovement
OK, so the '96 heads have the roller rockers, but what else accounts for the stated HP increase over the earlier EJ22s? Is it cam profiling and/or bigger valves? And most importantly, are these heads dual port heads?
Posted: Sun Mar 20, 2005 5:42 pm
I thought it was the 97 engine that made more power, and that it was primarily due to slightly higher compression...
Posted: Sun Mar 20, 2005 6:23 pm
The 96 ej22 heads are roller rocker, and have larger valves. They are not however dual port exhaust ports.
Posted: Sun Mar 20, 2005 8:17 pm
by entirelyturbo
Are you sure about the 96 EJ22 having roller rockers? I have an EndWrench magazine that says the 97-up EJ22's were Phase II, which included these changes: roller rockers, a bump in CR from 9.5:1 to 9.7:1, and thus becoming an interference engine...
Posted: Sun Mar 20, 2005 9:20 pm
I read here someplace that the '96s were roller rocker. So do the 97 up have the larger valves along with dual ports?
Posted: Mon Mar 21, 2005 12:22 am
no, none of the ej22's from 95 onward have dual exhaust ports.
Posted: Mon Mar 21, 2005 12:59 am
So that's why everyone goes to the 2.5s, then.
