Page 1 of 2
Found some interesting stuff (opened my block)
Posted: Mon Mar 21, 2005 4:21 pm
by TDGKORN
The good news:
piston squirters are all still in.
pretty good shape for 200+k
The bad news:
#4 piston in bad shape
#4 cylinder in bad shape
and the worst is the thrust bearing is completely destroyed
Troy
Posted: Mon Mar 21, 2005 4:59 pm
by professor
now you'll be forced to get the forged pistons you really wanted anyway
Posted: Mon Mar 21, 2005 5:04 pm
by TDGKORN
Forged pistons are overkill for what I want out of the engine.
300hp is all that I'm looking for. From the people that I have talked to the stock short block is plenty strong to do it.
I will be getting some different bearings though.
Posted: Mon Mar 21, 2005 7:12 pm
what bearings you getting?
Posted: Mon Mar 21, 2005 7:21 pm
by TDGKORN
I havn't decided yet, either cobb or crawford piston ones.
I just talked to
http://www.ccrengines.com/ and they said that the reason the bearing was chewed up so bad was the fsm has a wrong torque spec for the crank pulley bolt. The fsm says 76lb/ft and they say 125lb/ft.
Anybody else ever heard of this?
Posted: Mon Mar 21, 2005 10:24 pm
by boostjunkie
Yeah, that problem has been discussed on this board before. A few people had the crank pulley come loose a little bit and chew up the key. But no one's actually taken apart the engine and noticed internal bearing damage because of this.
It makes sense, tho. Without the dampener properly fitted to the crank, there will be excessive force on the crankshaft bearings.
Posted: Mon Mar 21, 2005 10:29 pm
by TDGKORN
They said that 9 out of 10 times if the main bearings failed, it had been within 6-12 months of a timing belt change.
Makes you want to retorque your pulley bolt doesn't.
I know I will tonight.
Posted: Tue Mar 22, 2005 12:31 am
by THAWA
Damn, maybe that's the cause of my failure. I did notice a wierd noise a couple nights after i finished the headgaskets but thought nothing of it because it only lasted a minute or so.
Posted: Tue Mar 22, 2005 12:33 am
by TDGKORN
Yeah mine started making a strange noise a few days ago. Hopfully its not to late.
Posted: Tue Mar 22, 2005 7:43 pm
by Matt Monson
Get the Cobb bearings. Sorry to see it in such bad shape. Hopefully it isn't so far gone that you can't hone it out without overboring...
Posted: Tue Mar 22, 2005 7:47 pm
by TDGKORN
I'm still looking for a machine shop that will even look at it. All the ones in my area are domestic only.
Posted: Wed Mar 23, 2005 12:05 am
by evolutionmovement
Maybe try a marine place. They have to do all kinds of engines.
Posted: Wed Mar 23, 2005 12:15 am
by TDGKORN
I finally found a place that can do it but, I also found out that there are no oversized pistons available from subaru.
this post talks about it
http://bbs.legacycentral.org/viewtopic.php?t=20735
There is a chance that I can hone the cylinders and take out the scuffing. If that works I can use a stock size piston.
I'm going to take some measurements tonight and hone the bore to see if its worth moving forword.
Troy
Posted: Wed Mar 23, 2005 12:26 am
by legacy92ej22t
IIRC a set of custom forged piston are actually going to run you about the same price as new OEM ones. Food for thought.
Posted: Wed Mar 23, 2005 12:34 am
by TDGKORN
My two posts should probably be merged.
sorry
Posted: Wed Mar 23, 2005 12:49 am
by legacy92ej22t
I responded in your other thread.
Posted: Wed Mar 23, 2005 12:53 am
I think Morgie paid like 130 for customs from cp pistons.
Posted: Wed Mar 23, 2005 12:54 am
by legacy92ej22t
Whaaa? I thought they were around $460 usd.
by TDGKORN
really?
They just quoted me $575 for a set.
Posted: Wed Mar 23, 2005 12:57 am
by legacy92ej22t
Posted: Wed Mar 23, 2005 12:59 am
by TDGKORN
That sounds a little more like what they quoted me.
Posted: Wed Mar 23, 2005 5:23 am
by morgie
I replyed to the other post
135$USD is what i paid for the custom pistons, including pins, locks, rings.
be sure to mesure your worst cylinder before ordering your custom oversized pistons! And verify with your machineshop what oversize they prefer work with. (.20mm, .25mm.. )
Posted: Wed Mar 23, 2005 5:57 am
At first I was like, whaaaaaa?!! The I realized you were using metric examples for the oversizing.
Posted: Wed Mar 23, 2005 1:31 pm
by morgie
oups yeah, i edited to include unit
ehe .20"Oversize, that's huge! haha
Posted: Wed Mar 23, 2005 4:22 pm
by professor
From the look of that scuffing, I don't think you have a chance of honing that out. It might look OK when you are done, but the eccentricity would be terrible compared to acceptable specs.
