broke another flexplate
Posted: Mon Apr 11, 2005 5:11 pm
by TDGKORN
This is the second flexplate in a year that has broken on me.
I have talked to everyone I can and everyone has a different opinion on it.
subaru tech: The bushing that supports the torque convter is wore.
Problem is you can't buy just the bushing, you have to buy the whole transfer case.
Tanny tech: Says the subaru guy is a moron, and that the flexplate isn't sitting flush with the crank.
Me: have no f'ing idea what is causeing it. But am sick of paying $60+ dollars and a weekend droping the tranny twice a year.
On a good note this was causing the wierd noise i've been hearing for a few weeks and not engine internals.
here is some pics of the last one. the most recent one is even worse.
Anybody else have any ideas?
Troy
P.S. both the subaru and tranny tech have never seen a subaru break a flexplate let alone 2. I guess I'm special.
Posted: Mon Apr 11, 2005 5:42 pm
Yeah I would say you are pretty special. I've never heard or seen it happen.
It looks like the plate is just shearing right off where the crank is bolted to it...right?
Do you see any deformity in the flex plate....is it bowed in or out at all?
What are you torquing the bolts to?
Posted: Mon Apr 11, 2005 5:47 pm
by TDGKORN
it is sheering right where the backing plate is bolted to it.
I'm torqueing everything to haynes specs (I don't remember exactly what). What is the fsm specs?
As far as I can tell there is no deformity, but I'll take a closer look tonight.
Posted: Tue Apr 12, 2005 2:50 am
Hmm....that's very weird for sure
Posted: Tue Apr 12, 2005 2:56 am
by dzx
I've got a flexplate you can just have if you come get it.
Posted: Tue Apr 12, 2005 3:00 am
by petridish38
Check to make sure that the alignment pins that go between the tranny and the engine aren't missing.
Andrew
Posted: Tue Apr 12, 2005 7:05 am
by Kelly
Get a new one. Weld a doughnut on the backside. Those things are so thin, and not the greatest quality steel to begin with.
Posted: Fri Apr 15, 2005 3:36 pm
by TDGKORN
I got the tranny reinstalled yesterday.
Man, I'm getting really good at droping and installing 4eat trannies. from tranny on the floor to car running it only took about 5 hours by my self (except to fit the tranny).
hopfully this will be the last time I have to drop it.
troy
Posted: Fri Apr 15, 2005 5:17 pm
by petridish38
Did you
l
l
V
petridish38 wrote:Check to make sure that the alignment pins that go between the tranny and the engine aren't missing.
Andrew
Posted: Fri Apr 15, 2005 5:21 pm
by TDGKORN
They were there but pushed out.
I punched them back in when the tranny was bolted up.
have you had problems with these also?
Posted: Fri Apr 15, 2005 8:36 pm
by 206er
what about doubling up 2 flexplates?
you can have mine if you want it
Posted: Sat Apr 16, 2005 2:59 am
by sammydafish
what about crank shaft end play?
Posted: Sat Apr 16, 2005 6:05 am
by petridish38
TDGKORN wrote:have you had problems with these also?
My brother had a broken flexplate on his SVX last year sometime... While he was fixing it, he read on some forum (forget which one now) that a common reason for broken flexplates on the SVX was missing guide pins. They are probably missing on many SVXs due to the high number of tranny failures and crappy mechanics fixing them and forgetting to put the pins back in.
While fixing his flexplate, my brother found that he had no guide pins, so he stole some from an EJ18 we had laying around the garage and hasn't had any flexplate problems yet.... If your pins are properly in place though, that kinda eliminates them as causing a problem
Damn!
Andrew
