Think I found my rough idle
Posted: Mon Apr 18, 2005 12:47 am
by magicmike
I noticed that down by the turbo my inlet pipe had some oil residue on it so I was looking around and saw that the vacume line was blown off the intake manifold nipple. I'm not sure what it goes to but I'm pretty sure it goes to some little valve under there and the other end of the valve goes to the fuel rail vacume thingy... so I put a small clamp on the vac line and stuck it on. the car seemed to drive the same but it also idled much nicer than b4. Just some info for you guys with a rough idle. Something to check I guess
