How hard will this be to find?
Posted: Sun Apr 24, 2005 6:03 pm
by 91White-T
Ok, two possible options, I'm assuming they'll both be a bitch to find since I haven't been able to at all.
1. GC coupe/sedan, OBD1, 5MT, AWD. 93-95?
2. BD/BG OBD1, 5MT, AWD. just 95?
Maybe I'm just TOO picky
Posted: Sun Apr 24, 2005 6:17 pm
There weren't any OBD-I BD/BG models sold in North America.
Posted: Sun Apr 24, 2005 8:36 pm
by 91White-T
Dang. I really like that body style too... So much for an easy turbo swap.
Posted: Sun Apr 24, 2005 9:35 pm
Why is a turbo swap much easier on an OBD-I car?
Posted: Sun Apr 24, 2005 9:47 pm
by scottzg
The harness on the 95 up legacies and na imprezas don't have the engine harness combined into the main harness. They go into the firewall and the layout is different.
Posted: Sun Apr 24, 2005 9:50 pm
Why exactly does that make a turbo swap much harder?
Posted: Sun Apr 24, 2005 9:57 pm
by scottzg
well, it's not the bolt in, swap 2 wires and ecu that the ej22 ->ej22t or the ej22 -> ej20g job is.
Posted: Sun Apr 24, 2005 10:34 pm
Oh. Neither is it that way for any car that doesn't use the same basic ECU design as ours, right?
Posted: Sun Apr 24, 2005 11:11 pm
by jamal
Why not get an OBD2 car and do a WRX swap?
Posted: Sun Apr 24, 2005 11:50 pm
by scottzg
I *think* (and i generally ignore swap stuff) that all turbo stuff through '98 and na stuff through 94 (93 for impreza) had the contained harness and it all makes for easy swapping, 1 or 2 wires and an ecu that plugs in. Then after that they went to a inside/outside engine compartment that complicates a swap.
obdi complicates things, as the obdi2 cars dont share the ecu design, of course, and at least in CA, you can't run a obdi2 engine on obdi1 controls.
I guess really it only makes going to ej22t harder, as theres plenty of obdi2 turboes running around
Posted: Mon Apr 25, 2005 12:05 am
The body and engine harnesses were/are integrated, but I don't think that makes swapping easier... It makes it hard because you have to sort through all the wires and figure out what you need and what you don't. Right?
Posted: Mon Apr 25, 2005 12:40 am
by scottzg
I dunno, as i said, i don't really pay attention.
I think that you don't really need to sort through because it's all pretty much the same, except for the engine control, and the slight na/turbo differences.
MM or a 20g person would know.
Posted: Mon Apr 25, 2005 2:06 am
by 93forestpearl
You need both complete harnesses out to do the electricals. Big mess. Lots of wire and connector swapping, after you unwrap lots of tape. Sportcompactcar did a write-up on it in the March '04 issue. They got their info from i-Speed who does the swap all day long. Their guy who swaps the harnesses takes 15-20 hours and he's done lots of them.
I thought about getting a wrx ej20 to put in. They can be had from nippon motors for $650. The wiring mess made me go with the ej22t.
Posted: Mon Apr 25, 2005 3:01 am
by BAC5.2
1995 was OBD2,
You need a 93/94 GC if you want OBD1
Posted: Mon Apr 25, 2005 3:38 am
by Tleg93
Ok, I know it's showing ignorance but what is the GC?
Posted: Mon Apr 25, 2005 3:42 am
by THAWA
gc=first gen impreza sedan
commonly called a gc8 here, but there were never any gc8s sold in the states
Posted: Mon Apr 25, 2005 3:45 am
by Tleg93
Thanks, Hardy, it helps to know the terms when reading the threads.
Posted: Mon Apr 25, 2005 1:54 pm
by 91White-T
Ok, so is 93-95 the right range for OBD1 Imprezas?
Posted: Mon Apr 25, 2005 4:12 pm
by entirelyturbo
93-94. All cars switched to OBDII in 95.
Posted: Mon Apr 25, 2005 4:29 pm
by totech
THAWA wrote:gc=first gen impreza sedan
Yeah, Mine is technically a GM6 lol..
Posted: Mon Apr 25, 2005 4:33 pm
by 91White-T
subyluvr2212 wrote:93-94. All cars switched to OBDII in 95.
Ok. Thanks
Posted: Mon Apr 25, 2005 4:35 pm
by THAWA
Not all cars, and not even all subarus. 96 it became mandatory.
