Damn rotors!
Posted: Tue Apr 26, 2005 1:38 am
by Subaru_Nation555
For the past two months I have been living with a vibration when braking in both the steering wheel and the brake pedal. I went to the mechanic and got new front rotors. Problem solved...for about 2 weeks. Then the problem came back-slowely at first but now the vibration is worse then before. Its much more pronounced at highway speeds but still evident at lower ones. I had two shops check out the tie-rods and the ball joints to make sure those are not a problem as well. So what's the deal? I don't drive like a maniac, there is no reason why this should keep happening. Can unevenly worn pads cause this problem? I want to do a WRX brake conversion but I need new tires more then I need new brakes. Any ideas? Thanks.
Posted: Tue Apr 26, 2005 1:43 am
Is it possible that your calipers are sticking and so overheating the rotors?
Posted: Tue Apr 26, 2005 1:50 am
by mikec
Are you braking heavily and then keeping the brakes applied once you've come to a stop? You might be able to see if you've got some pad imprints on the rotors without taking the wheel off.
Posted: Tue Apr 26, 2005 1:52 am
by Subaru_Nation555
vrg3 wrote:Is it possible that your calipers are sticking and so overheating the rotors?
That happened about 10,000 miles ago and as a result the front left caliper was replaced. Its possible that one of the calipers is doing that again. If that were the case would I smell the brakes overheating? Would the car pull to one side if only one caliper was sticking? If I can find a cheap set of WRX brakes I'll just say good-bye to the god awful SS brakes for good-they have been nothing but trouble. Anyways is there a way to check about a sticking caliper-perhaps disassembling it and cleaning? Thanks Vikash.
mikec wrote:Are you braking heavily and then keeping the brakes applied once you've come to a stop? You might be able to see if you've got some pad imprints on the rotors without taking the wheel off.
Didn't notice that happening but I don't brake like that too often. I'll keep an eye out for that though. Thanks.
Posted: Tue Apr 26, 2005 1:56 am
The simplest check that I do for sticking calipers is to just drive around without really using the brakes, then pull over and check to see how hot the wheels are. If a wheel is hotter than it should be it could mean the caliper is sticking.
A better check: if you undo the lock pin of the caliper, you should be able to slide it inboard and outboard without too much effort.
Mike's thought about your braking habits is a good one too... I usually try to coast the last few meters when I come to a stop, and if I'm stopped for more than a short time I creep forwards a little to change the position of the rotors.
Posted: Tue Apr 26, 2005 2:00 am
by mikec
Same here Vikash.
Thats a good idea for checking to see if you have a sticking caliper. I'd never thought of doing that.
Sacha, when's the last time anything was done with the calipers? Have the sliders been lubed in the last little while?
Posted: Tue Apr 26, 2005 2:50 am
10 bucks says it's your pads. Did you bed them in properly after the rotors were replaced?
What type of driving do you do? What type of pads are these?
Posted: Tue Apr 26, 2005 5:20 am
by Subaru_Nation555
Legacy777 wrote:10 bucks says it's your pads. Did you bed them in properly after the rotors were replaced?
My driving is a mixture of very casual and the occasional hard trip around town but nothign too crazy. The pads are EBC Greenstuff which suck. I tried to bed them in properly (several 50ish-5mph stops?) but maybe not.
Posted: Tue Apr 26, 2005 3:34 pm
After the bedding in process, did you give them enough time to cool off while rolling?
